My Asus A6Fseries Model nootbook Laptom have a problem. Here tuchpad is not working properly. cursor movement is fine but click or double click or right click is not work.
Typing emails and sporadic jump back or forward to where cursor was last.
Hi!
I think, when you are typing, you accidentaly touch touchpad, so it;s like mouse click, and cursor will be active where is mouse, To avoid this:
  • Pay attention to yoru fingers
  • When you are typing long text, turn of your tuchpad (FN + FX , FX = button F1-F12 look for mouse or touchpad icon)
Hope it helps
Jul 09, 2011 | Toshiba mini NB205N325WH 101" Netbook ...
The webcam inside my Laptom is upside down, how do I stand it up? Thank you.
http://support.asus.com/download/Download.aspx?SLanguage=en-us
downloaded newest camera driver
Jan 16, 2011 | ASUS U52F-BBL9 Laptop
I have a Sony Vaio VGN CS290. Just a few minutes ago the touchpad and the buttons were working properly. However, I suddenly cannot make a click/double click from both the touchpad and the left click...
This sounds like a hardware issue, however, you can do some troubleshooting steps:
First solution: Go to the mouse settings.
On the "buttons" tab, go to the "double click speed" area.
Slide the cursor all the way to fast and try clicking on the folder with your left mouse button,
If it opens easily, your button should be working.
If not, try sliding cursor all the way to slow.
Second solution: Download the latest touchpad driver from Sony Vaio website support drivers page and type in your laptop serial number and try to reinstall the touchpad pointer driver and restart the system.
Third solution: please perform a system restore, how to perform a system restore press and hold down the windows key on your keyboard and press the R key after that a window will pop up, in that command box type "rstrui" without colon and you will see the system restore page click next and you will see several dates, now select the date where your computer was working fine and then click next and proceed with the system restore, please note that system restore will not delete any data or files but it will uninstall only the programmes which you have installed on or after the date which you have selected to restore.
If none of these works try connecting a mouse and see if all the clicks are working fine and if that is working fine then it has something to do with the hardware of the click button of the laptop I would suggest you to take it to the service center and get it replaced it won't cost much.
Aug 27, 2017 | Sony 4-660-223-01 Touchpad Keyboard
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
When using the touchpad the cursor always double clicks
For that go to start menu->control panel->folder optitions.
Then you can see first general tab settings.
Make sure in "clci kitems as follows" the option button for "double click to open item " is enable.
Then apply and ok.
If still face same issue then uninstall touchpad driver and reinstall driver again then it works fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | Samsung NC10-14GW PC Notebook
The left click button on my samsung r510 is not working, can you help me please?
Use "tapping" to do the left click if the button isn't working. You can click, double click and drag things around using just the touch panel.
Position the cursor on the icon you want to select and do a quick "tap" on the touch panel, the icon will become selected, equivalent to one click. To double click, double tap. To drag things around, do a tap and quickly tap again without lifting your finger and move.
It takes a little practice but you'll get used to it. Also the touchpad software has some settings that will let to configure the sensitivity and time between taps among other things to adjust the movement to your preferences.
Oct 28, 2009 | Samsung R610-64G Laptop
Touchpad has no tap, left key not working.
I had this issue and resolved it by doing the following:
-Open the start menu by using the windows button
-Use the arrow keys to highlight run and press enter
-Type 'control panel' and press enter, find the mouse properties and enter
-From the buttons tab in mouse properties, go to double click speed and change to slow and confirm the changes
-At this point it probably still wont work, so do the above again but change the double click settings to fast and confirm.
-Restart your PC and this should resolve the matter. you can alter the double click speed again if you wish :)
Hope this helps,
tbo
Apr 06, 2009 | ASUS Eee PC 1000H Laptop
Wireless mouse
I just read one of the other solutions, and it was to try and press the reset and mouse reset buttons together - woked for me! yay!
Louise
Dec 08, 2007 | Belkin Optical Mouse F8E850-OPT
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
