Question about Sharp 32C241 TV
TV Turns off by itself
My TV while on ''shudders'' and black bars appear on the left and right as if the TV is resizing the picture and then eventually shuts itself off.
    Problem Solver:
May be the problem of your TV is Power shortage or the Horizontal Output Damage,Before you open the the said unit check your power supply if it is ok then check the voltage regulator of your television if faulty replace it with the same value,!!!!!!!!!!!!!!!! if doesnot work contact me 09098557731 delpacs! have a nice day!
Posted on Mar 25, 2009
    Sergeant:
  • 320 Answers
Its the tuner ic nuber 536 faulty on the main board or the capavcitor number c762 faulty.that needs replacement.
Posted on Mar 06, 2009
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
Tv takes to long to turn on and screen resizes
sounds like a power supply issue. partstore.com might have a power supply for this tv
Mar 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Digital Picture Frame Shows Black Bars
The nature of 16:9 basically means that you will be losing photo information in normally framed 4x5/5x7 photos. There is no way to fix this because the frame size of 16:9 is wider than 4x5/5x7. The options the frame offers are the only options to make your photos fit. Either crop, or distort.
The best solution is to keep this in mind when taking photos from now on and assume you will be cropping the top and bottom of the image.
As for the photos you have already taken, the only viable tactic to take is to reframe them for 16:9 yourself. You can download a free photo editing application like "GIMP" to do this. Create a new project that is 800x450 pixels. This will give you a 16:9 canvas. Next drag your existing photos into this canvas and move it around and resize it until you find a suitable framing for your picture.
Unfortunately it seems that as 16:9 solidifies itself as the new screen standard people are finding that shooting photos framed for 4:3 or in portrait dimensions are not translating well to this new standard. You may even want to consider returning this frame and looking for a 4:3 aspect ratio frame if cropping/resizing is not acceptable for you. Good luck!
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Used TV; new to me
type in PT-47WX51 manual in your search bar and there is an online manual from fixya. It will take you through setting up your tv.
Nov 06, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
98 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
