It can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked
how to replace the colour
wheel with diagram and procedure http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
hey mike. thereis no glass in there no bulbs havebeen smashed in it, gaz what do you mean i need a sub d connection between pc. im using the vga. also it doesnt have a usb port on it and whats a pj lol. thanks guys
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Set the lamp to economy mode, make sure it is being used in a cool room with easy air flow thru the projector. If the problem persists, there are two fans inside and a thermistor that takes the temp reading, there is small adjustment POT on the board to increase the operating temp if needed.
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
