Question about HTC Touch HD Smartphone
HTC touch HD camera problem
The camera suddenly not capturing pictures, giving the following massages: -
1- Tab the screen to activate the camera.
2- Unable to capture photo. Unable to get frame data from camera device.
I keep doing that but not working, also I restart my mobile no result, and finally I re-set the mobile to factory setting and give me massage that an error occurred and I have to inform Microsoft by the problem, I sent the report, till now still the camera not working .
  • 1 more comment
  • Anonymous Mar 20, 2009
    Same issue, any news?
  • Anonymous May 09, 2009
    camera wont start
  • Anonymous May 16, 2009
    black screen but with cross hairs still. After button pressed and picture taken get message saying unable to capture photo, unable to get frame data from device.
If you done, all what is possible. Now try do next:
Push camera button and wait until camera frame will loaded. Dont release camera button. Now push hard reset key. And during restart keep camera button. Whan system will loaded, you can try use camera.
Posted on Nov 28, 2009
The zoom tap buttons do not appear on my phone screen..could someone please help me.......
Posted on Jun 12, 2010
I want to unlock htc touch hd
You can Unlock it simple by using the Unlock code,You can get the Unlock code and instructions at here
moz-screenshot-1.pngTheunlockarena and Unlock it...You can follow the instructions below and Enter the code
HTC Touch HD Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HTC Touch HD mobile phones. If you enter over a certain amount of wrong unlock codes on your HTC Touch HD mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Touch HD with a Not ACCEPTED SIM Card.
2. If your HTC Touch HD asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch HD will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch HD is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your HTC Touch HD is locked to.
Jul 29, 2011 | HTC Touch HD Smartphone
"Memory is full. Please delete some messages."
Initially go to Internet explorer
select menu
select tools
select options
choose the memory tab
delete all cookies and temp files
If there are more messages in send items delete that too.
Hope this helps you
May 31, 2010 | HTC Touch HD Smartphone
I am having an HTC Touch HD T8282 Mobile . While doing the internet browsing , if I attempt to change the Screen Orientation it does not work . However it works for Videos & Picture files . Can anyone...
Go to 'Start > Settings > System tab > G-Sensor', and check how your browser is handled there, and adjust its settings, if needed.
Hope you are able to sort your problems out.
Cheers! Carlos
May 08, 2010 | HTC Touch HD Smartphone
Touch flo background...
its probably the default but with windows you most likely cant change it
Jan 22, 2010 | HTC Touch HD Smartphone
Computer can't see HTC HD Touch Camera not working either
Click on the following:
1. Start
2. Settings
3. Connections
4. USB to PC
5. Click on Activesync (Sync with Outlook) option
6. Ok
Aug 22, 2009 | HTC Touch HD Smartphone
Htc stopped working it hangs on home screen
i had a hard time understanding your question- but iim guessing its a software glitch.... what i did to reset mine was redownload the telstra rom from the htc site (htc.com/au/- then go support- then in dfrop down choose htc touch hd- then click download on htc toucch hd rom upgrade asia- then choose telstra settings and download- should be like 100 odd mb.... once installed connect hd to com via active sync (make sure more then 50% battery) and open up this rom update... follow installation instructions and let it run (all automatic- only for htc touch hd tesltra bought in aus) - be aware that this will wipe all stuff on the phone (not memory card) ie calendar contacts (so backup using active sync b4 update your rom) after all this turn on your phone again and it should start up like the first time u ever turned it on ie touch calibration and time/date etc (this should fix any software glitches)
May 22, 2009 | HTC Touch HD Smartphone
AIRTEL GPRS settings for HTC Touch P3452
THIS SHOULD HELP U......
On Windows Mobile 6.x, the steps to configure are as follows:
1. Activate Airtel Live by sending the following SMS to 121: MASALA ACTIVE.
2. The service takes atleast 3-4 hours to get active. Restart the phone and resume configuring.
3. Tap Start -> Settings.
4. Select Connections Tab and tap Connections.
5. Select Advanced Tab, tap Select Networks button to bring up Network Management.
6. Under "Programs that automatically connect to the Internet should connect using:" drop down, tap the New button.
7. In the General Tab, type the name of the settings as Airtel Live
8. Select Modem tab, tap New...
9. Type the name of connection as Airtel Live, select the modem as Cellular Line (GPRS) and tap Next.
10. Type Access Point Name as airtelfun.com and tap next.
11. Leave username, password and domain blank and tap finish.
12. Select Proxy Settings tab. Tap "This network connects to the Internet". This should enable the next check box option.
13. Tap "This network uses a proxy server to connect to the Internet".
14. Type the proxy server as: 100.1.200.99 and then tap Advanced...
15. Tap HTTP, leave the server as 100.1.200.99 and change the port to 8080
16. Similarly tap WAP, Secure WAP and Socks, type the server as 100.1.200.99 but leave the port to defaults. These are optional settings.
17. Tap OK to close the Advanced proxy setup screen.
18. Tap OK to close the New connection screen.
19. The network management screen should now list the new connection you have created in the drop-down. Tap OK to close this screen
20. Tap OK to close the connection screen.
Now you are ready to fire your favourite browser. I have tested this on PIE as well as Opera 9.5 and it works for me.
If PIE reports "Request not authorized by the WAP Gateway", you will need to change the user-agent to anything you can think of using "Advanced Config" tool (thanks to dsixda for suggesting this). I had set it to HTCP3452_Mozilla/4.0 under Advanced Config -> Internet Explorer -> User Agent Custom Base.
I think Airtel has intentionally blocked Mozilla/4.0 user-agent on WM phones. It may be that they cannot restrict Windows Mobile based phones from accessing websites on standard HTTP. On other phones I had tried, I could not get other sites to work with the same settings.
Enjoy Airtel Live for free.
Mar 23, 2009 | HTC Touch P3452 Smartphone
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Take picture from HTC Touch Diamond phone
you open camera application now swipe yor finger across the hard keys to enable / disable auto focus. now when you find a nice picture you want just press the area on the screen you would like to capture after a second the picture you have taken will appear.
Jan 19, 2009 | HTC Touch Diamond Smartphone
HTC Touch HD Smartphone Logo
2,827 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
