My PC is always shutting down,,
What was the main cause why my PC always shutting down.. and what am i gonna do to stop this action.. THANKs
  • Dan rogers
    Dan rogers May 11, 2010
    What is the pc doing when it shuts down? Blue screen? any error boxes?
May you have given your hard drive a minute to shuts down at the power management so please check it or you are having virus on your computer it can also cores that
Posted on Mar 06, 2009
  • villarsato Mar 06, 2009
    i need product key for xp park2
  • 83 Answers
Main problem is heating or may be virus in ur system....
so check pressesor fan is working properly and it not heat much....and check virus status in ur pc...
also check smps fan..
thanks
bye
Overheating and shut down d915grv
CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heat up beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heat up.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heat sink.
1. Make sure the fan is running. (if not, it needs replacement)
2. Clean the fan and heat sink (thermal module). Take out the fan and heat sink. clean them with the help of tooth brush and put it back.
3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 27, 2013 | Intel D915GAV Motherboard
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
Overheating
CreativeTECH
May 27, 2013 | Intel Computers & Internet
Inspiron 518 - intermittent power up, amber light blinks once and then stays off
Usually if it has boot issues it is from the ram memory ..specially if it does like you said ..only ask for repeated action when it is cold..So , check the ram memory to be well plugged in ..and if you made changes , check for the specs on the newer ram module and be sure it is not on a higher speed or so ..cause it will not read it well and issues will be caused by it ..
another thing can be some bad points on the hard disk ..and if you get a bad on the system it may fail to load for good..The idea is to reinstall the operation system from scratch using a boot-able disk ..and this may fix the issue for the moment ..until it will be stuck with a system file in a weak point ..
The reinstalling is recommended also in case you added more ram memory and never reinstalled This action will force the computer to recognize the ram memory in proper way and run better ..
If you see it is always makes issues when you put it to sleep mode or shut down ..you may enable the hibernate mode (from the power management panel ..(somewhere near the screen saver settings in the desktop properties ) ..and after that select for the actions when you press the main button to go to hibernate mode..This mode will always save what you have running and it is slightly different from the shut down cause it saves the running program and teh configuration used on moment ..and just load back the same way ..and it may force it to use the same points on the hard disk all over again when it starts ..
I used this mode on computers with hard disk issues and it always worked better than starting over again ..
I hope it was helpful and please do not forget to rate my answer ..
Have a good day !
Nov 14, 2011 | Dell Inspiron 518 Desktop Computer
Hello, my Optiplex, whenI am playng, suddenly shuts down. I mean there isn't a SW crash, only the PC shuts down and I am obliged to reboot. May be a temperature problem? Tanks Marco (Rome Italy)
Gaming consumes more CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heatsink.
CreativeTECH
May 31, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Window shut down when scanning.
That is mainly caused by your laptop CPU heat too hot. Just clean the CPU fan and dip some lubricant oil into the CPU fan. Then buy a laptop cooling stand.
Or you can take a look at http://www.laptops-battery.co.uk/blog/how-to-replace-the-dell-processor-thermal-cooling-assembly/
May 13, 2010 | Computers & Internet
My toshiba satellite L350 is always shutting down. what am i gonna do. and i just want to ask how to reboot my laptop?
try to reset all settings from your cmos setup, if not work you need to reinstall or reformat your laptop
May 09, 2009 | Toshiba Satellite Pro L350-S1701 Notebook
I've had a bad dust problem and my cpu fan began making a loud whirring noise and finally the computer shut down altogether. Took the cover off totally cleaned out the dust and turned the power back on....
If the computer detects overheating or fan failure it will shut down automatically. If you replace the fan you should be fine. Remove your old fan and try to get one that connects the same way, some of them connect directly to the heat sink, others to the motherboard.
Apr 16, 2009 | Sony CPU FAN CPU Fan
When i play sims 2 it always hang then my pc will shut down automatically. the spec of the games are compatible to my loptop what will i do?
There is a problem of overheating. Maybe the specs are almost exactly the same as the game requirements. So the PC still has to work hard. This causes overheating, which should not happen if it is even perfectly compatible.
So, this means that something is causing the computer to overheat. Firstly, shut down any open background programs. Also, see that the laptop vents are not blocked by any thing around. Remember to dust the heatsinks, fans and the casing. Also, the keyboard and main vents. If you can, vacuum it all and open up the casing to be sure that all the gunk is out.
Jan 30, 2009 | Toshiba Satellite A75-S231 Notebook
Blue screen - kmode exception not handled - ntoskrnl.exe
I feel some program running in the background is causing the problem.
Try using msconfig and disabling unneeded softwares from startup. Then restart the PC and try to shut it down check.
Let me know what happens.
May 01, 2008 | Compaq Evo D500 PC Desktop
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
