Question about Lexmark C533DN InkJet Printer
Inkjet cartridge replacement
I have replaced the cartridge with a new one but my computer and printer still tells me 'Ink level low cartridge needs replacing'
    Sergeant:
  • 320 Answers
You need to select the ink level with a procedure.just go to printer properties there go to to printing preferences there go to lexmark solution center and there you will see the option called install a new cartridge .click that option and follow the on screen instructions.and in selecting coloum select the cartridges as new .then the ink level will become proper and will work properly.
Posted on Mar 06, 2009
Which ink cartridge is empty
It may be in your printer drivers, however shaking a cartridge wont help they have a sponge holding the ink if you have a scale that reads in grams you should be able to tell which one is empty
Nov 21, 2012 | Epson Stylus CX4800 All-In-One InkJet...
Printer says that ink levels are low when in fact they are not. I don't want to have to replace them all for no reason.
Brother Cartridges contain no Electronic Chips to Gauge the Ink levels. Simply removing one cartridge at a time, slowly, then replacing them will bring up a display asking if they are new or old cartridges. if you tell the printer they are new, your ink levels will be re-set. Ink levels on most printers are only a guide also. If you want simply ignore the warnings, keep an eye on your inks manually. But be careful not to run them completely dry as printing in this state can cause the print head to burn out, and destroy the printer!!.
Regards GM
Apr 07, 2011 | Brother DCP-110C All-In-One InkJet Printer
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Low ink levels after replaceing with new ink cartridges
Hi
Dell's Inkjet, All-In-One Printers ... cartridges have a sensor in them that cannot be reset.
Sorry
Feb 03, 2010 | Dell 926 All-In-One InkJet Printer
I just purchased a new computer and now I do not have a tool bar showing low ink. How do I know which cartridge to replace when the light blinks low ink
You need to reinstall the S/W that came with the printer on your new computer. If you do not have the disc, you can go on line and download the driver and the S/W that detects and displays the ink levels. You would see the ink levels when go to print a document.
Jan 21, 2010 | HP DeskJet 960c InkJet Printer
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Polling the ink cartridges for available ink level.
http://files.support.epson.com/pdf/r220__/r220__pg.pdf
then click on replacing ink supply, and the first box down tells you about ink cartridge levels.
There you go Utah
Please leave rating...thank you kindly
May 10, 2009 | Epson Stylus Photo R220 InkJet Printer
NO WAY TO TELL WHICH INK IS LOW OR NEEDS REPLACING ON STYLUS C88+
Sounds as if you have either Linux or a Mac computer. There are ink level monitors for these operating systems, However there can be problems installing them.
On Windows the ink level monitor should pop up when printing. It is part of the printer utilities. Open printer properties and set the options desired.
When the printer stops printing, press the ink button and remove the indicated cartridge and replace. If more than one remove and shake next to your ear, replace the empty cartridges only. A tiny amount of ink remains in the cartridge when empty. This amount is so small it has a distinct sound signature compared to a part used cartridge.
Feb 20, 2009 | Epson Stylus C88 InkJet Photo Printer
Overiding Empty Cartridge error for Dell A10 962
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Lexmark C533DN InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
