Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
ECS 945gct-m2 CMOS error
When i open my computer it always say that "F1 to resume" when i press F1 it enters to cmos setup,, this always happen this past days,, it is not like this when i first bought my motherboard,, what will i do??,, plsss help me experts,,
,,i know you can help me,, Thank you so much for your help in advance,,
  • 54 Answers
When you enter the bios...go to the setting where you have the option your reset the bios to manufacturer...Once you do that it will work without any problems...It sounds like the bios setting might have been accidentally modify..
Hope that helps
Thank you
Posted on Mar 06, 2009
Ibm 2akt49aus
Just guessing, but I'd system your CMOS battery needs to be replaced. Open the computer side panel and search the motherboard for a small, round silver batter about the size of a nickel. Use your fingernails to push the silver click to one side and take out the battery. Buy a new one from Wal-Mart and put it in with the smooth side up then re-enter the CMOS setup information and the problem should be solved.
May 22, 2014 | IBM Lenovo ThinkCentre® M51 (814339U) PC...
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Hello, when I put my pc running it says CMOS checksum error press F1 to enter or Del to enter setup, but I press Del when I save changes "save and exit" the computer restarts, but this time...
The Checksum error basically shows that boot settings which were previously set has been changed or reset. This usually happens when the battery loses its charge and thus fail to retain the CMOS settings. This can also be caused by a power surge or a damaged motherboard. But most of the times it would be the battery problem.
You can try replacing the CMOS battery and enter the values back into CMOS or reset values to default. Then switch off and boot up again.
Hope this works. Good Luck. ~SmokinJoe~
Apr 28, 2011 | EliteGroup KM400-M2 Motherboard
Cmos settings incorrect press F1 for setup. Replaced the cmos and reset jumpers and still the same problem.
bios setup F1
make sure you load optimal/default settings and your hard drive primary/Operating system drive boots first F10 save ok enter
Jul 04, 2010 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
Press F1 to resume at start up?
When you go into you setup screen,choose the setting that you want,then tell it to save the settings. If irt is loosing the setting then likely  the cmos battery is bad and needs to be replaced.
Mar 01, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
My usb controller is not enabled i cant use the usb ports..
go to the CMOS setup of your motherboard. to do it turn on your computer, and it will display in your screen to press a certain key such as del or f1 or f10 key to access the CMOS setup. once inside the CMOS setup, look for the enable USB controller. enable the USB controller then waaala. your USB controller is now working.
Dec 22, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Prompt to enter setup when started
press del to enter to cmos and set to load setup default and select exit and save changes and if happen again replace your cmos battery.
Nov 24, 2008 | Computers & Internet
OPEN PASSWORD BIOS
How to enter the BIOS or CMOS setup. Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
Press <F2> to enter BIOS setup
Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
Should get ya back on line , Good Luck
Dec 01, 2007 | Fujitsu LifeBook C4135 Notebook
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
553 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
