Question about Hitachi 51UWX20B 51" Rear Projection Television
Hitachi 51UWX20B spider web like lines help
I have a Hitachi 51UWX20B 2002 model and I just noticed spider web like lines running horizontally across the top 3 inches of screen ,they even move like a spider web.Is it possible to take the screen apart to clean or is this some other problem ? Thanks John
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Posted on Jul 23, 2009
Same thing happened to my set. I removed lower back cover and cleaned inside. it was spider webs with dust accumulation. cleaned the mirror as well. picture was amazing after that clean up
Posted on Jul 22, 2009
Hitachi 51uwx20b magic focus worked a few times but not now
It is very easy to determine weather if you need to do a convergence repair or just make an adjustment with your TV's original remote. Take a look at this youtube video...
Hope this helps!
Nov 19, 2011 | Hitachi 51UWX20B 51" Rear Projection...
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
I had my 51uwx20b tv for 7 great years. for the
needs soldering the bad connections on the convergence board
Nov 17, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
I need an owners manual
www.Hitachi.US.com..........Click on Support and Contact......
Dec 17, 2007 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi 51UWX20B 51" Rear Projection Television Logo
307 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
