Question about Sceptre S1902D 19" LCD Monitor
My sceptre monitor S1902D won't turn on just stopped
  • 19,396 Answers
If the monitor has no power at all then you have a dead power board, or a broken power cord, test also a different wall AC outlet.
If instead there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Posted on Mar 06, 2009
2 Suggested Answers
  • 105 Answers
SOURCE: problem with sceptre monitor
I have repaired a few of this model by replacing the failed capacitors in the power supply.
Monitor Mike
Posted on Apr 30, 2010
Will it support TV (rca) a/v input through vga
That should work because a/v and vga are analog.
Dec 16, 2013 | Sceptre S1902D 19" LCD Monitor
My screen has gone to a blue tint. What is the life expectancy for a screen?
Blue tint (Red tint, or Green tint) is more likely due to one of the pin on the VGA cable is bent ot the cable is not seated properly of the the video card conectors may be the problem. Try it with another PC and check the pins.
LCD monitors usually fail after about two years due to bad caps.
Basic LCD monitor and LCD TV troubleshooting guide:
Failed TV, Monitors, Caps :
Learn about bad caps:
Capacitor kits: he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | Sceptre S1902D 19" LCD Monitor
I powered the monitor off 1 evening after watching movies I was useing the monitor as a second monitor on computer doing multi tasks, but now when i turn it on i just get a black screen it lights up at...
Your computer may not be seeing your second monitor. Go to your display settings and see if you computer is seeing monitor 2.
A fast way to check is to plug this monitor in as your primary on the computer to see if it works.
Mar 09, 2010 | Sceptre S1902D 19" LCD Monitor
My sceptre 30" lcd TV monitor turn on a few second then turn off only the sound is still on.I try to turn on/off many times and some time it works some time it doesn't. Could you please help what is the...
It can be the problem in the backlight inverter board or the power supply problem. You need to open it up and start looking for bad caps with bulging top first. Post back what you see inside. See example of failed monitors due to bad caps:
Mar 06, 2010 | Sceptre S1902D 19" LCD Monitor
Monitors work well for a while then have trouble booting up
It is a symptom that like T.V's usually manifest before they go busted. I also had that kind of problem before. Then after 4 to 5 months, my monitor just has a black screen. It powers on, but still a black screen.
Sep 04, 2009 | Sceptre S1902D 19" LCD Monitor
Problem with sceptre monitor
Monitor Mike
Dec 23, 2008 | Sceptre S1902D-4 Monitor
Microtek S1902D monitor
if you have a flashlight.... shine it into the back of the monitor thru the vent holes.... do you see a anything displayed on the screen ... while the computer is on of course.
Aug 29, 2008 | Sceptre S1902D-4 Monitor
was she playing with the keyboard. ??
She/he may have shut off the monitor from the keyboard. look for a little picture of the monitor.
Sometimes you need to hit fn (function) key and the display key to toggle it on
May 08, 2008 | Sceptre S1902D-4 Monitor
No picture
I fixed mine. Had to replace one bulging capacitor in the power supply. Yours may need more or less but it was pretty easy if you do any electronics. The specifics can be found under some of the other problem posts, especially for one of the 19" sceptres.
May 04, 2008 | Sceptre 17" LCD Monitor
Sceptre S1902D 19" LCD Monitor Logo
2,129 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
