FixYa.com
Tags:
Compaq 60GB Laptop for Presario 700 Series  Hard Drive
Problem with Partition Magicv 8.0 and Compaq...
By Mini Me - usenet poster
Hey all,
I just bought a new Compaq Presario R3140US. I installed Partion
Magic 8.0 on it so that i could partition off a 20 gig section of the
60 gig hard drive. However, when i tell the program to do it's thing,
it resets the compuater to take care of what it has to do, but during
the process i get a error #983 "too many errors". It seems no matter
ehat I try, i cannot partition a section of this HD. I have heard
that this is a common problem with trying to use Partiton Magic on
HP/Compaq laptops - but i haven't seen any solutions yet.
I heard one person say there is a small partition on all new compaqs
that hosue some OS files, and that it would prevent other partitions
from being able to be createdis that the case? If so, what
shoudl I do?
Thanks a TON in advance for all of you help. You can email me at
Thanks again,
Matt
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
FixYa! (100)
Green1
Green1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
magicianstalk said in
"HP Pavilions that shipped with Windows XP do not include recovery discs
in the box. The recovery information is stored in a hidden space
(partition) on the hard drive. This eliminates the need for Recovery CDs
that can get lost or scratched."
bph07144). Yeah, cheap a-holes! In contrast, you can create backup
copies of the CDs to store offsite so you can perform recovery in case
of fire, theft, or from malcontents. I've also yet to suffer a CD
scratched sufficiently to prevent it from being used (guess it depends
on how abusive you are) but I have had hard drives fail. Supposedly you
can obtain recovery CDs from Compaq (now HP) but probably at some cost,
and I suspect these "recovery CDs" are merely disk images that don't do
an install but instead wipe out everything in the partition to lay down
the same image as when you bought the thing.
What partitions does PartitionMagic report? Does it say there is only
one lone 60GB partition occupying the entire hard disk? Even if a
hidden partition were used to keep a copy of the install files for the
OS, PartitionMagic should show that partition (any partition not listed
in the partition table won't be immune from getting its space reused
since it will appear to be unallocated space on the drive). If you've
gotten stuck with a Compaq that went this super cheap route of using a
hidden partition to consume your hard drive's space instead of just
giving you a CD which is pretty cheap in bulk, you'll need to find out
how to save it or use it other than in that hidden partition since that
is your ONLY copy of the OS from which to install or repair. I thought
Compaqs that used a hidden partition on the hard drive gave instructions
in their manual on how to create CDs to use instead. No? Compaq also
creates other partitions, like their System Partition just for utilities
Did you run 'chkdsk /r' (which will require a reboot) to ensure the file
system is okay and no bad sectors are found?
Did you create the PartitionMagic rescue diskettes and try booting using
those to run PartitionMagic? That prevents PartitionMagic from having
to use any portion of the operating system from the partition you are
trying to resize.
I think Powerquest uses Caldera DOS (DR-DOS) on their bootable floppies.
I have also found that sometimes Caldera DOS will cause problems when
running their DriveImage program, so you have to switch to using
MS-DOS/Windows9x to create a bootable floppy and move over their
config.sys, autoexec.bat, and other files from their first rescue
diskette to the MS-DOS/Windows9x bootable diskette, boot using that
modified diskette, and then use the second rescue diskette as-is. If
you don't have MS-DOS/Windows9X-ME to create a bootable floppy as a base
bootable floppy to modify, go to #. I haven't yet
bothered to use the bootable floppy that users claim that Windows XP
will create when you format a floppy.
*** Post replies to newsgroup. Share with others.
*** Email domain = ".com" *AND* append "=NEWS=" to Subject.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
The only free help you can get from powerquest/symantec is is the program
will not install otherwise they will charge you 30 dollars for any other
help. Typical symantec behavior.
Regards,
Werner
Remove "Nospam" when e-mailing
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (#).
Version: 6.0.703 / Virus Database: 459 - Release Date: 6/10/2004
Solution #3
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
There is a patch for version 8 to verison 8.01. Check the version you are
using via HELP -- 3/14/2003". Be sure that yours is at least as new as this version.
Other thoughts include contacting PowerQuest support. However, since they
have been absorbed by Symantec I do not know whether they will still reply
as fast. Of course, reading the on-line help/FAQs at the Symantec website
might prove useful.
Solution #4
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
I had the same problem on a Compaq Presario 2100 lap-top I recently bought.
Wonder if its a generic Compaq compatibility issue?
BTW - I'm using P-Magic Version 7.0, but its never let me down before.
Anyway, I ended up using the Windows recovery CD supplied with the laptop to
do a clean install of Windows. Gave me a chance to delete the existing
partition, and create 2 new ones on the disk instead. Didn't take too long,
and the suite of recovery CDs contained all of the drivers, software etc. -
so I'd recommend going down this route if all else fails.
Solution #5
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
Have you run chkdsk /f to make sure the partition is free from errors?
PM won't work if there are errors on the drive. If it's clean then
contact Symantec tech support and Compaq for help. PM is a good program.
Solution #6
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
What you should do is complain to Partition Magic and/or HP/Compaq; it's
their problem.
Can you Help with these Hard Drives problems?
Hard Drives
usb Zippys is not working in hp...
This problem is existing for... Answer This...
Hard Drives
External hard drive
Good afternoon. I am having a... Answer This...
Hard Drives
Drives being read as a file.
Hi, When I click on my computer... Answer This...
Hard Drives
Western Digital hard drive usb...
the usb port fell off in side... Answer This...
Hard Drives
Dowload Drive for my...
Dowload Drive for my... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
