Question about Jet 414458 HVBS - 56M Horizontal/Vertical Bandsaw
I HAVE THE JET 414458 HVBS SAW.THE SAW CUTS ROUND STOCK CROOKED.IT LOOKS LIKE THEBLADE IS IN CONTACT WITH THE STOCK AT THE START OF THE CUT AND ABOUT .250 AT THE END OF THE CUT THE STOCK IS 1" IN DIAMETER
  • fred700 Mar 12, 2009
    THANKS HATTER1.THE ADJUSTMENTS SEEM TO SOLVE THE PROBLEM.IWILL TRY THE LENOX BLADES RIGHT NOW I HAVE A CHEAPER BLADE ON THE MACHINE
  • 22 Answers
There are two possible reasons for your band saw to cut crooked.
1 is the set on one side of the saw blade has worn down and you need to change your blade, or
2 your band saw blade is not square to the bed of your band saw.
If the blade is brand new and it still cuts crooked then you need to square the blade to the bed. To check if the blade is square to the bed, lift the head of the saw up a couple of inches and take a square and set it on the bed. Slide the square up to the blade and to see if there is a gap between the edge of the square and the blade. Try to pick a spot on the blade where the tooth is straight or bent away from the square. If there is a gap you'll need to move both blade supports in or out until there is no gap between the edge of the square and the blade.
If you are unable get it squared yourself, contact the place you bought the saw from. They maybe willing to send a service tech out to do it for you. Some band saw blade makers are also willing to send a service tech out to correct any problems that you may have. Lennox is one such company that may send a service tech if you are using their blades.
Hope this helps you,
Hatter1
Posted on Mar 09, 2009
  • bart braun Mar 09, 2009
    Sorry, I should have said "blade guide arms" instead of "blade supports"
    Hatter1
How do you lock femi 782xl Bandsaw for vertical operation
BandSaw at Trick-Tools
vansantent.trick-tools.com/tools/BandSaw
BandSaw found in: Femi NG160ABS Benchtop Semi-Auto Mitering Bandsaw, Ellis 1600 Dual Mitering Head ... ...that has a locking valve for setting up cuts. ... The HEM Saw 782XL portable bandsaw is a great fit for hobbyists and those needing an accurate portable ... JET HVBS-56M, 5 x 6 inch Horizontal/Vertical Bandsaw.
Band Saws, Horizontal & Vertical - Trick Tools
www.trick-tools.com > Sawing
Find Band saws in a variety of configurations including horizontal, vertical, ... Bandsawblades are a long lasting and low cost consumable, reducing the maintenance andoperating cost of this type of ... Femi 782XL Benchtop Mitering Bandsaw.
FEMI 782XL Swivel Head Portable Bandsaw 110 volt
www.stakesys.co.uk > Shop By Category > Metal Cutting Band Saw
The 782XL can be locked in a vertical position and, when used in conjunction with the optional table kit and quadrant, used as a vertical bandsaw for cutting ...
' The Saw That Cuts Straight
www.hemsaw.com/
Dec 16, 2015 | Saws
Bandsawbladeveerstoright
I have 7 x 12 band saw. I always read articles on bandsawblog.com. They have very helpful and informative blogs about band saws. I purchase my blades on sawblade.com . I am very satisfied with their blades, you should try it your self. Give them a call.
Aug 28, 2013 | Jet 414459 HVBS - 7MW Horizontal/Vertical...
I have a stock #414457 Jet bandsaw and when I try to tighten up the vise, it jumps back before it's tight. I think the problem is with the
If you need parts for your band saw, you can visit www.bandsawparts.com . They offer cheap aftermarket parts of Jet band saws.
Nov 08, 2012 | Jet 414459 HVBS - 7MW Horizontal/Vertical...
Cuts crooked
A saw wont cut straight if the cutting plates are of different lengths or blunt, due to improper sharpening. Take it to a repair shop or a hire centre and they might put it right. You might be better with a new chain. Stephen.
Dec 06, 2009 | Garden
Ryobi Bandsaw model EBW4023L will not cut straight
I do a lot of resawing with mine and I have found that a 3/8" wide blade gives me nice straight cuts.
Jun 19, 2009 | Ryobi 9 in. Benchtop Band Saw
Wobble blade /rough cuts
You may wanna check the Conveyor Cart Wheel. Replacing this wheel maintains smooth rolling action which contributes to straight, chip-free cuts.
It costs for only about $28.72. Here, you may check this link if you wish to buy the Conveyor Cart Wheels:
http://www.diamond-blades.net/target_tile_saw_access.html
Unfortunately, I couldn't find any service center where you can bring your Target Tile saw for repair. But you may check the manufacturer's contact number on the user's manual.
Have a great day!
May 30, 2009 | Target Saws
Manual for band saw
I don't think these Jet 414459 HVBS manuals are available online, but the Jet site suggests you may acquire them by contacting Consumer Relations at 800-274-6848 - 8:00 a.m. to 5:00 p.m. (CST, Monday - Friday).
I guess that will work if you're in USA.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 24, 2009 | Jet 414459 HVBS - 7MW Horizontal/Vertical...
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Jet 414458 HVBS - 56M Horizontal/Vertical Bandsaw Logo
484 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
