Question about Connex 3300 240-Channels Base CB Radio
Iv got a problm with mt swr i have a magnett mount on the trunk of my car and a pretor 2 antenna and my swr is 5 on both ends ch. 1 & 40
  • 463 Answers
What sort of antenna are you using? Wilson, K-40, etc? Also, is the antenna right near any metal or perhaps you have heated rear glass (which means you have thin strips of copper in close proximity to your antenna).
Any of these things can cause enough impedence mismatch to cause your VSWR to rocket skyward.
Posted on Mar 06, 2009
It says cb atanna warning when i key the mic. i have a new cable and new atannas as of 20 min ago. what is the problem
The problem is you need to tune the antenna.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Aug 10, 2011 | Cobra Radio Communications
Got it peaked and tuned and hooked up a new coax and mirror bracket and my swr is at 4. Before I did all this I had the stock coax and swr was under 2. What do I need to do to get the swr down?
The antenna needs to be tuned. The reason all of a sudden your SWR is a 4 when it used to be a 2 is, after a peak and tune, the radio is putting out more power, there for more RF energy is being reflected back into the radio. That is why the antenna has to be tuned.
1. Turn to CH 1
4. Turn to CH 40.
Nov 17, 2010 | Cobra 29 LTD CB Radio
I need to know how to tune my cb radio. I have a Cobra 19DXIV and I can only hear certain people and they have to be within 50 feet. I also need to be able to hear the people close to me and people that...
1. Turn to CH 1
4. Turn to CH 40.
Nov 15, 2010 | Cobra 19 DX IV CB Radio
I hooked everything up the way it said but i get nothing on every channel....also when i drive i here a lot of feed-back
Im not sure feed back is the correct description. You can only have feedback when you transmit. I think you are talking about interference from the car.
First lets address the issue of hearing nothing....
  • Make sure the coax is tightly screwed onto the back of the radio.
  • Depending on the type of antenna, for fiberglass antenna, make sure its grounded properly, for mag mount, make sure there is nothing wrong with the mebrane on the bottom of the magnet, and that you haven't put anything in between the magnet and the car.
  • Make sure the mic is plugged in. You will have no receive if there is an issue with the mic.
  • Make sure you have tuned your antenna. This is important. If you don't you will ruin your radio.
As for the interference. Some times devices in a car can cause interference to the radio. Here are some ways to battle that.
  • Make sure ANL is turned on. This is the Automatic Noise Limiter.
  • If you have the power wire connect into the fuse box, try running it straight off the battery.
  • If that does not stop the interference, then got to a truck stop, and get a power wire noise filter.
Also, I am including information on tuning your antenna below.
1. Turn to CH 1
4. Turn to CH 40.
Nov 15, 2010 | Radio Communications
I just got a cobra 29ltd army edition and i cant get the SWR right
Takes some time to get it down if you are new to it. Here is a step by step instruction on setting it.....
1. Turn to CH 1
4. Turn to CH 40.
Nov 12, 2010 | Cobra 29 LTD CB Radio
I lost my manual and I don't know how to calibrate my CB its a cobra 29Ltd chrome edition
1. Turn to CH 1
4. Turn to CH 40.
Oct 21, 2010 | Cobra 29 LTD CB Radio
I have a cobra 150 gtl dx cb radio. my reception and transmition is not at peek performance. can you help me please? i have tried everything i know to do.
If this radio has been peaked and tuned already, and it is not in need of a full alignment, then it's most likely the antenna.
Your antenna is everything. You need a good antenna, and it needs to be tuned to the lowest SWR.
1. Turn to CH 1
4. Turn to CH 40.
Oct 20, 2010 | Cobra 150 GTL DX Base CB Radio
I am showing a antenna issue with both my galaxcy and the new cobra cb i bought i replaced the wire with a 18in but still didnt solve the problem
Did you try adjusting the antenna for lowest SWR? If so, the problem could be your antenna. It might be a poor antenna.
1. Turn to CH 1
4. Turn to CH 40.
Oct 18, 2010 | Cobra Radio Communications
High SWR
the problem is in the antenna cable. the lenth of a antenna cable must be divisable by 3. try replaceing cable with a 18 foot cable that should fix the problem.
Apr 11, 2009 | Cobra 19 DX IV CB Radio
Connex 3300 240-Channels Base CB Radio Logo
46 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
