Question about Microsoft Xbox Console
Xbox 360 1022 error
Hello everyone
I got problem whit my xbox 360 the red light is flashing (4th not all of them)
I did eject code and i get error 1022, I tred to change AV cable to many diferent ones but its a same thing....
But one thing I found out then i take a cable off it starts work normaly ( I mean green light start flashing) so maybe it problem whit conection and not whit HANNA or ANA chips....??????
  • romancik Mar 07, 2009
    ye but what to do when???
  • 81 Answers
Yes its the hardware problem not with ur cables or something
hey please vote me man i want to be a guru i tell u some tips if u vote me
Posted on Mar 06, 2009
  • venkatesh babu
    venkatesh babu Mar 07, 2009
    you have to give it to a shop coz if you open it you can get any other hardware problems
My xbox stop working i have not even had it for a year and a half and i want to know whats going on?
hello hi there i just recieved your comment on your xbox??whats wrong with it exactly?has it got 3 red lights showing?if so please say,if it has 4 red lights just plug the cable in better or its a error code being shown whats the numbers comming up the xbox 360 is more intelligent than the ps3 all you have to do to find what the correct error code is- press at the same time the eject button and at the same time the sync button and it will flash the lights if the whole 4 parts of the lights flash at once that means code 0 if you press it 4 times like that in total it will give you the 4 digit error code which is how you define whats wrong with your xbox a lot more precisely any more questions just ask please give positive feedback im trying to sort this problem out personly you with untill its gone so please at least give me positive feedback and i hope we can fix your problem together.thank you p.s. go to my website if it helps you xbox360repairspro.webs.com
Jun 04, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Where light is for controller port four its flashind red and xbox will noy work?
hi, this is what that code is telling you, also do you have a code on the screen when switched on let me know if you do if you dont ill tell you at the end of this post how to get an error code so i can tell you exactly what the problems is.
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
here is how to get the secondary code for me.
The specific type of hardware failure can be determined by a "hidden" error code
* Turn the xbox 360 on, and wait till the 1 red lights are flashing.
* Press and hold the sync up button (the small white one), while holding that button press the eject button.
* The LEDs will now blink the first number in the code ( so 1 red light may be lit so write this down).
* Release the eject button and press it again.( it will then change the red lights and maybe 2 will be lit up write this down also)
* The LEDs will now blink the second number of the code.
* The LEDs will now blink the third number of the code.
* The LEDs will now blink the forth number of the code.
* The LEDs will go back to the 1 red flashing lights.
so what you need to do is this, when the 1 red light comes on hold down the little white sync button and keep holding it down all the time, now whilst your holding that little white button down on the front of xbox press the eject button but keep holding the white button down now write how many lights are lit up and this is the 1st number in the code, so keep holding the white button down dont let go of this white button then press and let go of the eject button again and write how many lights are lit up whilst still holding the white button down, now do this 4 times all together and you will end up with something like this written down
4402
once you have this four digit code send me a message back with the code then i can tell you exactly what the problem is and what you can do to try and solve the problem
let me know how you get on or if you need further assistance ok
Dec 12, 2010 | Microsoft Xbox 360 Console
My xbox360 has one red light flashing
1 red light usualy means hardware failure. There is another error code you can get of of xbox. While machine is on push the the sync button on console and while sync is pushed in press eject button. The lights on the console will give you youre first digit. Theres 4 in total. Repeat pressing the sync and eject button till you have got the four digits and console is back to the red light.
When getting codes the lights will light up. 1 red light means 1 2 means 2 and so on. 4 red lights means 0. Let us know and ill get back to you.
Apr 05, 2010 | Microsoft Xbox 360 Console
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
The LEDs will now blink the first number in the code (as described below).
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
Cannot get a connection from wireless internet to game-
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
Dec 04, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Exbox 360 4 red ligths
4 red light is a problem with your AV cable.
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the xbox 360
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
    You can also check to see what the error code is yourself if your not sure whats wrong with it.
    To do this, you turn your x-box on, press the Connect button on the console itself and hold it in. Now press the DVD eject button to and look at the lights. it should be flashing 1 light, 2 lights, 3 lights, or 4 lights. grab a piece of paper and write down how many lights are showing. While still holding the connect button, press the eject button again. Write down how many lights are showing again. Then press eject again, and write it down. Then do it one more time and write it down. After you do this, then come back on fixya.com and let me know what error code it is.
    1 Red light = 1
    2 Red lights = 2
    3 Red lights = 3
    4 red lights = 0
    so an example of what you might write down would be:
    0
0
0
which would be 0001.
If you figure out the error, you can also visit the following website and determine what it is and if you can fix it yourself:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 24, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
2,157 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
