Question about HP LaserJet 3050 All-In-One Printer
Laserjet 3050 scanner error 6 - HP LaserJet 3050 All-In-One Printer
  • 67 Answers
  1. Disconnect power
  2. Open the scanner section (you need torx)
  3. Move the scan unit halfway the transport rail
  4. Close the scanner section
  5. Reconnect power
I recently had this problem and I solved it this way.
Posted on May 06, 2009
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
52scans error in hp 3050
Turn off power and wait 30 seconds. Power on and try again. Still fails...is it plugged into a surge protector? Plug it directly into the wall. If the error persists you are going to have to replace the "laser/scanner" assembly
Oct 19, 2009 | HP LaserJet 3050 All-In-One Printer
Pcl xl error kernel illegal tag 0xlb 6 HP 3050
Re install the driver for the printer or the best thing is format the system
Jun 19, 2009 | HP LaserJet 3030 All-In-One Printer
Scanner does not work message Waiting for PC
my hp laserjet 3050 prints but i need the driver to scan a document.
Apr 18, 2009 | HP LaserJet 3050 All-In-One Printer
Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Dec 07, 2008 | HP LaserJet 3050 All-In-One Printer
52 scanner error turn off and on is displayed in the contoll panel,the same thing is again displayed if i turned off and on also nothing can be printed due to this displey. please help
The printer has burned a scanner assembly. The part number is RM1-2033-030CN. The part is extremely expensive in relation to the printer cost. ($182.00 @ HP)
I would recommend surfing ebay for an HP Laserjet 1022 printer as it is the cheapest printer that has the same scanner. Even a dead 1022 will work as they tend to either have formatter or fuser issues when dead. A scanner error on your printer or the 1022 is extremely rare.
I have included a link to the HP 3050 service manual for you that will walk you through it step by step. The teardown is significant however very do-able by the novice with the service manual.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/service.html
Good luck, You can do it.
Jul 09, 2008 | HP LaserJet 3050 All-In-One Printer
52 scanner error
52 error are error in printer scanner not in the copyer scanner..
replace the scanner inside the printer..
Jul 03, 2008 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 scan problem
You should go to HP.com and look for a TWAIN scanner driver the works for that printer in Vista.
Jun 14, 2008 | HP LaserJet 3050 All-In-One Printer
HP LASERJET 3050 SCANNER: ERROR (not set up on pc).
Shirley,
If your still looking for a solution, or to those of you who have a similar problem, the following fixed my problem after trying to resolve the issue over the last year!!!!
I also received the "not set up on pc" message and tried re-installing the software numerous times.
Finally resorted to re-installing windows XP (because of this and other software glitches) and re-installed the Laserjet 3050 software again...but could not get the printer to install.
The problem was occuring while the software was asking to "plug in the usb cable", but would not complete the installation. It was not recognizing the device....the solution was to reset the laserjet 3050!!!!
to reset, push the "menu" button, < (left arrow), go to "service", "enter" button, > (right arrow), "Restore Defaults", "enter" button.
This should reset the factory defaults.
After this, I re-installed software, working!!!!!
Puas
Dec 14, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
319 people viewed this question
Ben Johnson
