Question about Samsung Televison & Video
Is samsung HLR5067WAX/XAA PU01 made for HD? - Samsung Televison & Video
4 Suggested Answers
Sparko1
  • 167 Answers
SOURCE: Green Plaid lines on Samsung HLR5067wax/xaa-
These are the Tests that should be run to determine which board is bad.You should call a good TV Tech if you are not familiar with this TV.
- The DDP1011 on the DMD board has a feature to display internal test patterns.
- DNle, which is an end port in the digital board, has a feature to display internal test patterns.
- The analog board sends signals to ADV7402 on the digital board.
- The analog board is the first output and the digital board is the second one, followed by DMD, which is the final one.
■ Diagnosis By Module
1. Access Service Mode
(In Standby mode, press "Mute", "1", "8", "2" and "Power" to turn the screen on and enter service mode)
2. Check if there is an error in the DMD board
DDP1011 → TEST PATTERN → Press the right arrow key:
Options of FULL WHITE, BLACK, RED, GREEN and BLUE PATTERN are displayed on the screen.
If "Pattern" does not appear, this is a DMD board error.
3. Check if there is an error in the digital board before the DMD.
When the DMD board has been determined to be error free based on the test patterns:
FACTORY MODE → DNIe → TEST PATTERN normal display: no error in the digital board.
If "Pattern" does not appear, it may be from a DMD board or ATI error or there is an analog board malfunction.
4. Check if there is an error in the analog board.
Check for a power signal from the analog to the digital boards
Posted on Jul 30, 2009
electronick
  • 505 Answers
SOURCE: my sasung HLR5067WAX/XAA keeps shutting off,I have
which leds flash? all 3 = lamp error, could be lamp, ballast, or colorwheel or dmd board (rare)
Posted on Jun 07, 2010
SOURCE: my samsung HLR5067WAX/XAA picture is getting
The 120 Watt lamp is probably losing High pressure Sodium and will need to be replaced. Lamp Code BP96-00826A (P120W)
Would be the first thing to replace.
Posted on Nov 22, 2010
How do I get my remote to work for my Samsung DLP hlr5067wax/xaa?
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts have details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
If the remote control is its original one, it should work with the TV without any problem.
May 01, 2014 | Samsung Televison & Video
Samsung HDTV - HLR5067WAX/XAA - popped, went dark
You had a surface mounted capacitor (AKA "CAP") let go on one of the circuit boards, open the set up and look for a small burnt area on the circuit boards inside the TV, it is likely it will be the power supply board, but that is just a guess..
Apr 13, 2017 | Vivitek Televison & Video
My sasung HLR5067WAX/XAA keeps shutting off,I have replaced the bulb & blew all of the dust out,help!!!
Jun 07, 2010 | Televison & Video
My samsung HLR5067WAX/XAA picture is getting darker slowley but surely
Mar 11, 2010 | Samsung Televison & Video
Purple dots on HD LCD samsung model LNT4661FX/XAA when on.
http://www.youtube.com/watch?v=Mm51C_RDIZE
-and-
http://www.youtube.com/watch?v=BNHHrgX_6cs
Jan 27, 2010 | Samsung Televison & Video
Need a lamp :code BP96-01073A(P) Model HLA5067WAX/XAA Version PU01, how do I find one
The (P) stands for Phillips which was the original bulb used by Samsung.
Since your TV was manufactured Samsung has started using other bulbs in their TV's.
If you do a search on the internet you will still be able to locate a Phillips bulb w/housing, just type the complete bulb# in the search field.
Sep 09, 2009 | Samsung Televison & Video
Turns off and on with no help from me
are you a technician if so go to the relay circuit and fix that circuit more than likely has bad ic like the eprom .
are leaky transistor also check the power button for lose connection they are tiny little switches now a day
Feb 22, 2009 | Samsung TX-R3080WH 30" TV
HLP 4663WX/XAA
sounds like the color wheel has gone out
Dec 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Closed caption
You have to activate the closed caption option on your charter cable box. Power off your cable box and immediately push the menu button. A menu should appear where you can toggle captioning on/off. Good luck!
Oct 27, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Televison & Video Logo
255 people viewed this question
Henry  Thomas
Henry Thomas
