Question about O2 Xda Orbit Smartphone
How to get into bootloader
I am having trouble getting into bootloader mode pls help
  • O2 Master
  • 13,433 Answers
The bootloader is invoked by pressing down the Record button and using the stylus at the same time to press the RESET button at the left side.
more info
http://wiki.xda-developers.com/index.php?pagename=Artemis_BootLoader
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 06, 2009
Motorola defy phone bootloader 09.10 code corrupt
my motrolla defy is a 2.3.7 version and and need to know how to sort out this code corrup please help me
Nov 10, 2011 | Motorola Mobility Defy Cell Phone
On my phone is just a blue screen and it say's bootloader usb init.pls help!..
hi :) here wanna tell u your phone software has been corrupted ! ok,let have a make sure test. hold press * # then press on/off button. (phone in off mode) if phone showing boot mode,show the software version. i sure it software problem. what u need to do is send for technician help u reload again software.
if my solution useful,please rank me,thank..
Jul 18, 2010 | Motorola Cell Phones
Unlock
I should first point out that there are other options to unlocking yourself, since this option is a bit more involved and can seriously mess up your phone:
1) You can get the unlock code from your provider for free if they are prepared to give it to you. If they are then that is the safest and best option.
2) For $25, you can use TheMotoGuide's unlocking solution which is instant and guaranteed.
That being said, here's directions on how to unlock the phone yourself:
*You need to downgrade your boot loader to 7.D0, be aware that this can be risky.
* You may find afterwards that when starting in bootloader you have only a blackscreen, so long as the phone works ok and you can connect in bootloader that is nothing to worry about
* Ensure your phone is fully charged before starting. I recommend before beginning you first make a backup of your phone as described in the back it up section. Especially the PDS back up. This assumes all necessary drivers are already installed.
1) Start in bootloader mode (hold # and * while powering on)
2) Identify your current bootloader (e.g. 8.26 or 7.E0)
3) If you already have bootloader 7.D0 skip to step 6
4) Download bl_826-828_to_07d0_for_V3_by_Archy.V2
5) Flash with this file using RSD Lite (described at the Flashing and Flexing section)
6) Download and extract the MOTO UNLOCKER SOFTWARE
7) Start in bootloader mode (hold # and * while powering on). In bootloader mode after the downgrade it is not unusual for the phone to show a blank black screen with no info, don't worry, though, it is still in bootloader mode!
8) Open up Moto Unlocker and connect you phone
9) Run Moto Unlocker click connect and yes! Once finished it will look like this:
Congratulations, your Motorola Razr V3 is now unlocked
Jun 13, 2010 | Motorola Mobility RAZR V3
My HTC p3400i is not coming back to normal mode from flash/bootloader mode..??..Help....
First you can try to soft reset your device. After that, you can try a hard reset just by pressing and holding both the " -" keys right above the answer and end keys and pressing the power button . It will run the ghost image and recover the device ...
Note :
1) make sure your battery is more than 50 % charged .
2)you must do a power cycle in your device ( take out the battery , then press and hold the power button ) before you do a hard reset ...
Video: http://www.youtube.com/watch?v=R53104JTgNI
If none of these helps, you can try to reflash your ROM (Since you're already in bootloader mode), simply plug your PDA to your computer with a USB cable, and download an upgrade ROM from here (http://forum.xda-developers.com/forumdisplay.php?f=408) or just download your original ROM from HTC website and flash it using the instructions in the xda-developer forums. Hope this helps.
Apr 21, 2009 | Cell Phones
AFTER FLASHING MOBILE DEAD POWER IS`NT ON.
It sounds like you've had problems writing a custom ROM to your phone. You have done it correctly using the CID unlock. Are you using the same WM6 ROM that you have done before?
Firstly, turn off your XDA Orbit.
Then hold down the voice recorder button on the left side of the phone
Then press and hold the power button on the right side of the phone, whilst still holding the voice button on the left.
This should get you into "bootloader mode" which will display a screen with red, green, blue and white stripes - yu should now be able to instlal your ROM using the RRU from the computer with USB connection
If that is not possible, you can install the ROM from a microSD card if you first format the card into Fat32 file system from your computer, then copy the NBH file from your ROM to the microSD card. You will need to rename the NBH file from the ROM to ARTEIMG.NBH for this to work.
Enter bootloader mode and you should see a prompt to press the volume button downwards to start the ROM installation process.
See this page for more information on the MicroSD ROM installation:
http://wiki.xda-developers.com/index.php?pagename=Artemis_SD_Card_Flashing
Nov 09, 2008 | O2 Xda Orbit Smartphone
TROUBLE WITH MOTOROLA RAZR V3
you can take the phone to have it unlock properly...it is in TEST MODE.
Aug 21, 2008 | Motorola Mobility RAZR V3
Phone only on bootloader
bootloader is the programing mode for when motorola loads the operating system. Typically this will happen when a bad flash code is used. You can try and remove the battery while the phone is turned on and hope it reloads the OS. Otherwise talk to your carrier about warranty stuff.
Jan 20, 2008 | Motorola Mobility RAZR V3
Bootloader
  • ok to program
  • transfer mode:
  • serial rs-232
  • the same problem...help...!
Dec 22, 2007 | Motorola Mobility RAZR V3x Cellular Phone
O2 Xda Orbit Smartphone Logo
1,064 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
