Question about MSI AMD ATHLON-64 939 PIN MOTHER BOARD (MBK8TNEO2939) Motherboard
Re: K8MM-V K8MM-V it just came up on my dashboard saying my Front page is corrupt. Check Motherboard.
  • 167 Answers
Hi, check the cmos battery then set the correct values, fsb,clock settings, again if you need more help. good luck!
Posted on Mar 07, 2009
How to connect switch on/off from board to case
Put your mouse cursor in the middle of the photo. Now move it around. Any bigger than that, and you need a microscope.
Bottom RIGHT corner. See where it states JFP1? From it go UP the motherboard. There is a mounting hole, then the Front Panel header.
It has Black, and Red, and Yellow, and Green, and Blue in it, below it's contact pins.
MicroStar International Support > MSI K8MM-V motherboard > Support Main page,
Hover your mouse on Download.
(Overview / Specification / Download / Support / etc)
In the drop down list click on - Manual
Under the Download subheading click on the blue -
Click on either Download 1, Download 2, or Download 3.
(Or click on the country name nearest yours. I have never seen Download 1, 2, and 3 before)
A small window will come up on the right -
Make SURE there is a Green dot, in the small circle to the left of Save File.
If there isn't; left-click in the empty circle to the left of Save File.
Now go to the bottom of the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download, then DOUBLE-click right on the file name.
Another small window will come up.
Go to the far left of this window, and click on - Extract all files
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
Now DOUBLE-click on the file name - M7142v1.0,
next to the red Adobe PDF icon.
There is your motherboard manual.
The PDF file page, and the actual manual's page, are not the same number of page.
Go to Page 5 - Adobe Reader page number, or Page 1 - Actual manual page number.
Be sure to note JFP1 and JFP2.
(Junction Front Panel 1 and Junction Front Panel 2)
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is JFP1.
JFP2 is an auxiliary front panel header. Explanation follows.
JFP1 is two columns of pins.
5 on the Left side; 4 on the Right side.
Pins on the Left side are numbered ODD.
Pins on the Right side are numbered EVEN.
Starting at the Top, coming down on the Left side;
Pins 1, 3, 5, 7, and 9.
Starting at the Top, coming down on the Right side;
Pins 2, 4, 6, and 8.
There is NO pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light. Usually Red)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C.
Not connected.
Probably 5 Volts used by the factory for testing the motherboard.
D) Pins 2 and 4 are for the Power ON LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO pin 10.
JFP2 is to the Left of JFP1.
Two rows of pins.
3 pins on the Top row; 4 pins on the Bottom row.
The 4 pins on the Bottom row are for a speaker.
For an internal speaker so you can hear BIOS Beep Codes.
Pin 2 is all the way to the Right; Pin 8 all the way to the Left.
(2, 4, 6, and 8)
Believe Pin 2 is for the Positive ( + ) wire. Pin 8 the Negative ( - ) wire.
The 3 pins on top are for a Power On LED light, that has 3 wires.
A dual color LED. (Yellow/Green? Normal/Turbo)
For additional questions please post in a Comment.
Nov 17, 2012 | MSI K8MM-V Motherboard
Problem with the MSI 7050 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
Sorry, I can't find a color diagram. But check page 2 of the HP support manual, this shows all the jumpers and board connectors. You can download the manual from the link below:
May 20, 2011 | MSI K8MM-V Motherboard
My K8MM-V motherboard is not recognising any SATA hard drives.
Plz check your motherboard is support new generation SATA speed. May be the MSI K8MM-V 'll not support 3gbps speed drives. So you need to change the HDD speed to 1.5Gbps by changing the jumper setting of HDD (plz refer HDD manual)
Sep 07, 2010 | MSI K8MM-V Motherboard
Sir, I can not get a Motherboard driver of model No-MSI K8MM-V you are requested to give me details information that How can i get the above mentioned mother board driver. Thanks.
You can download the required drivers from:
On the page which opens, download the appropriate drivers depending upon your PC operating system.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Sep 03, 2009 | MSI K8MM-V Motherboard
You could try flashing to the latest bios and disabling SATA RAID
here you can download bios and it is included the software to run for update.
please also read the attention note at this page.
this page belong to your motherboard MSI K8MM-V
Apr 19, 2009 | MSI K8MM-V Motherboard
What is the maximum size of HDD supported on a mother board say MSI board say - K8MM-V (MS-7142) ? How do we detrmine this value ?
Dear sir,
i dont think there is any maximum size of HDD supported by any motherboard.....
But now a days 320 GB is the maximum size of HDD attached with any pc....
do reply
Jan 23, 2009 | MSI K8MM-V Motherboard
MSI AMD ATHLON-64 939 PIN MOTHER BOARD (MBK8TNEO2939) Motherboard Logo
32 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
