Question about Saeco Vienna De Luxe Espresso Machine
2 green blinking lights
Our Vienna De luxe's 2 green lights are blinking and we can't figure out how to stop them and make coffee.
  • 1 more comment
  • brotherL25 Mar 08, 2009
    2 blinking (-pardon me-!) green lights, but no coffee. The lady has lost the manual, if ever there was one. Solution please??
  • Maffi1990 Apr 23, 2009
    I have the same problem with mine. Two green lights blinking, when i click the steamer, it stop blinking on coffe and start working on the steamer, but when i click on the coffe, nothing happens.
  • Ernest R
    Ernest R May 11, 2010
    There are 3 green lights one for the machine being on/off and one for the machine heating and another for the hot water. Which ones are blinking 1 and 2, or 2 and 3. If 2(middle light) is blinking then the machine is heating or trying to heat up if light is blinking for more than 6 mins. I would check the thermostats on the element and the element.
    Problem Solver:
  • 8 Answers
This is a cold boiler problem.
There are several reasons for a cold boiler...boiler element is open, no power to the boiler element, thermostat is not functioning properly, or it could even be a board problem not delivering voltage to the boiler.
First start by opening the top and reseating all connectors on the board, if this does not help then you will have to extract the insides of the machine from the case to get at any of the boiler and thermostat hardware.
Start by removing the 1 screw holding the inside workings to the outer case. This is located on the right top side of the machine beside the grinder.
Use great caution while pulling the guts out of the case and watch the dredge drawer switch does not hang-up on the case. Snake the power cord through the bottom of the case while pulling the inner workings out of the case.
There are 2 elements in the boiler check them both for a resistance (they will not be the same resistance) if either are open then then replace the boiler. Check the thermostat on the back of the boiler for resistance, if open or shorted, then replace. Check thermal breaker on boiler, this should be shorted if not, reset it by pressing the button in the center of the breaker.
If none of this works then you will have to depress dredge drawer switch front door switch and insert the brew group to depress the brew group switch, plug in the unit and turn it on.
Check for voltage on the elements on the boiler.
If no voltage then check all connections.
If you have gotten this far there is a good chance it is the board fault and it will need to be replaced.
Be shure to label all connections to the mother board as there are several connectors that can be placed in the wrong position while reassembling.
NOTE: This depth of trouble shooting should only be attemted if you are completely comfortable with electrical/electronic repair.
Posted on Jun 24, 2009
Red light showing when i go touse frother steam not consistent
For Saeco Vienna De Luxe Espresso MachineTeam De-Brewerz.com says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler. You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Oct 20, 2014 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna de luxe no coffee comes out
The brew unit is blocked, remove unit and then remove the screen located at the top, clean screen and reassemble.
Jul 03, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe grinds but plugs up at door
Try this: clean out the chamber, then set the grinds coarser to see if it makes a difference. If it does not then the micro switch or solenoid that controls the door is broken. Check resistance on solenoid it may need to be replaced.
May 10, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe not transferring grounds to brew group?
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Aug 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe (Trevi)
Hi Mike,
Try to open the steam knob to see if the pump is starting.
Jul 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna de luxe
Try to open the steam knob to see if the pump start.
Jul 04, 2008 | Saeco Vienna De Luxe Espresso Machine
Broken coffee maker
I don´t no realy what you mean, if you have the door open so will the machine be dead, there are a switch in the machine that power off when you open the door.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
You can download a manual at www.cerinicoffee.com
Jun 10, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
719 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
