Question about Dell Latitude D630 Notebook
Bluetooth on but not identified - dell latitude d630
I have BT' it's on (the blue sign lights).
In device manager I can see devices - RFBUS, RFHID, and "dell wireless 360 bluetooth module".
I cannot use it with Nokia PC suite nor does it appear on the control panel - I don't even have BT option. How can trun on my Blutooth device and how can i work it...?
2 Suggested Answers
SOURCE: bluetooth on but not identified - dell latitude d630
I solved the problem of the missing bluetooth icon by running windows update to get the latest 360 stack driver for the BT radio. Works like a charm now. Good luck.
Posted on Oct 21, 2008
iqbal_del
  • 652 Answers
First of all search device from your nokia phone near to your lap-top. If its found your lap, then you have to checkout your lap BT settings.
Other wise go to Device Manager and Uninstall your BT brivers.
After that make reboot then install driver for your lap BT.
You can download the driver for your lap BT from the following link or any where else.:
http://www.wireless-driver.com/download/bluetooth/dell/Dell-Wireless-360-Module-with-Bluetooth-20-EDR-Driver-Download.htm
Thanks.
iqbal_delphidev@yahoo.com
Posted on Mar 05, 2008
How to enable Bluetooth in Dell Latitude E 4310
u need to have to installt he bluetooth software then u can enable ur bluetooth
Sep 22, 2011 | Dell Latitude E4310 Laptop
How to enable blue tooth
    • 1 Open the Dell Latitude E5400"Start" menu and navigate to "Control Panel." Click "System and Security" if your E5400 came with Windows 7 or "System and Maintenance" if it came with Windows Vista.
    • 2 Choose the "Device Manager" link. Windows Vista also requires you to click "Continue."
    • 3 Click the plus sign next to the "Bluetooth Devices" entry near the top of the list of devices. Right-click the entry for the Dell Latitude - E5400 internal Bluetooth adapter and select "Update Driver Software."
    • 4 Select the option to "Search Automatically." Click "Finish" after the latest driver is downloaded and installed.
    • 5 Close the "Device Manager" window. Locate the blue "Bluetooth" icon in the notification area at the bottom right of the screen. Right-click the icon and choose "Enable Bluetooth."
    • 6 Turn on your Bluetooth-enabled device, such as a cell phone or PDA. Navigate through the device's menu to the "Bluetooth" option and select "Enable Bluetooth," or the equivalent option for your device.
    • 7 Right-click the "Bluetooth" icon on your Dell Latitude D600 again and choose "Add Device." Click the name of your detected Bluetooth device and click "Next" to connect to the device.
Aug 18, 2011 | Dell Latitude E5400 Laptop
Latitude D600 PC Notebook: i have dell latitude D630 laptop when i turn on...
Do you have the drivers and software installed for the bluetooth module - you need to make sure that you have the correct Dell package installed in order for it to be registered.
Have you also checked under the computer device manager - does the bluetooth device show there?
I would also check in the BIOS to ensure that the bluetooth module is showing there and is set to enabled.
Hope this helps
May 17, 2010 | Dell Latitude D600 Notebook
I have dell d630. bluetooth is turned on from BIOS but not getting icon in my system tray. No idea what is the problem.
Step By Step:
1. rightclick My Computer, click Manage.
2. go to Device manager, and find your bluetooth radio. It will most likely have a <!> Icon because windows does not know what it is.
3. rightclick the bluetooth radio and do Properties, advanced.
4. Find your device's HWID (HardwareID), the shortest one listed.
Next we will tell windows to use a driver it already HAS, to run the radio.
5. open up c:\windows\inf\bth.inf in notepad.
You will notice a section of entries like:
Broadcom bth58685 = USB\1232134234
6. Create a new line with whatever name you'd like it to show up with, and your HWID from device manager.
7. save the file.
8. go back to device manager, rightclick the bluetooth radio and do 'update driver', 'find driver automatically'.
9. If you've done steps 5 - 7 right, it'll find the driver, install Microsoft Bluetooth Support, and you'll be up and running.
Feb 14, 2010 | Dell Latitude D630 Notebook
Unable to send and receive data via bluetooth
you need to turn on bluetooth by using function keys. Press Fn button and button with sign of antenna simultaneously.
Sep 14, 2009 | Dell Latitude D600 Notebook
Enable bt on dell latitude d630
Press Fn+ F2 to enable bt and WiFi
Thanks, Prem
Apr 10, 2009 | Dell Latitude D630 PC Notebook
Latitude d630 bluetooth
If it is not the D630 ATG,you may not have the blue tooth chipset.
It was an option on the other D630 models.
Jan 15, 2009 | Dell Latitude D600 Notebook
I have latitude d630 how to switch on bluetooth.BT driver installed n shown at task baar
Dear there is a switch on the front or the look for the symbol of bluetooth and there might be a switch. kindly on that switch and you can transfer data through blue tooth.
Dec 03, 2008 | Dell Latitude D600 Notebook
Dell latitude d600 pc notebook, infrared and bluetooth problem
Check the device manager to see if the drivers for the infrared device are there. If they aren't there, then go to Dell's site and download them. If they are, unistall, reinstall, the check Dell's site for updates. If the device manager shows everything working properly, the device itself may be malfunctioning. The same procedure for the bluetooth device.
Jun 22, 2008 | Dell Latitude D600 Notebook
Thanks.
Mar 05, 2008 | Dell Latitude D600 Notebook
Dell Latitude D630 Notebook Logo
322 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
