Question about Cameras
I have a hanimex sekonic light meter but have the instuction manuel
    Problem Solver:
  • 12 Answers
Http://www.sekonic.co.jp/English/product/meter/download.shtml
Posted on Mar 06, 2009
Is it possible to take apart & clean a Hanimex 72-162mm lens? If so, how?
Is it possible yes, is it recommended no. Lenses are full of little tiny precise parts that are difficult to assemble. The smuges you see are probably mildew. This will eat into the coating on the lens. Hanimex was a an importer based in Australia. They did not manufacture lenses themselves. I have used many legacy lenses on Olympus cameras, Hanimex and others. As a general rule I found these lenses did OK as a macro but only average in general use.
Sep 22, 2014 | Cameras
Can hanimex tz 7000 flash gun be used on Nikon D90
The Hanimex tz 7000 was made for the Minolta. So the shoe won't fit. But there is an extra danger. The old camera's switched with a real mechanical switch, and did not bother for eventually high voltages coming to the switch. Modern camera's like the D90, but almost all digital camera's use electronic switches, who can be damaged when a high voltage from the flash comes in.
I would not use it on one of my digital camera's.
Perhaps you can find a cheap remote switch for the Hanimex and trigger the flash remotely. otherwise, save some money and buy a modern flashlight.
Sep 16, 2014 | Cameras
Sekonic Flashmate water damage
It may be permanently damaged. However you can try this - pack it in a bag of uncooked white rice and leave it there for a few days. Uncooked rice is hygroscopic - it absorbs moisture from the immediate surroundings.
Apr 01, 2014 | Sekonic L-308s Flashmate Light Meter...
Instuctional manuel for canon printer mp620
You may download the manual and more from here.
Jul 03, 2012 | Office Equipment & Supplies
I use the settings recommended by my L358. However, when I set my camera to those settings in manual mode, my photos are dark. Why is this happening?
The fault is either with your camera/lens or with the meter itself. Try the meter with another camera, if the exposure error is still present then check that the custom compensation feature on your meter has not been set by mistake (page 26 of the user manual). If this doesn't cure the fault then try fitting a new CR123A battery. If the fault still remains then you can either compensate for the error by always using a longer shutter speed/wider aperture than recommended or you will need to send the meter for servicing.
Good luck, and please take a moment to rate my answer.
Aug 29, 2010 | Sekonic L-358 Flash Master Light Meter
How do I program? I lost the instuctions.
You didn't mention the specific model of your timer, but here's a link to a manual that I hope will work for you:
http://www.aubetech.com/manuel/2/TI032.pdf
Dec 17, 2009 | Aube Technologies Aube 7-Day Programmable...
L-358 light meter doesn't change modes
Most probably the switch under the Mode button went faulty. Try to operate the button many times, sometimes it helps, if the culprit is corrosion or small debris inside the switch. If not, have the meter repaired at Seconic.
Oct 12, 2009 | Sekonic L-358 Flash Master Light Meter
Sekonic L-358 light meter will not trigger my photogenic lights anymore? Thanks, Liz
Hi Liz
have you checked your sync cable?
tried meter on another system (for comparison)?
Depends where you are.. Mamiya in the USA can solve the problem.
Jun 08, 2009 | Sekonic L-358 Flash Master Light Meter
Meter is consistently a half to a full stop off
I've known this problem to occur if the wrong kind of CR123/CR123A lithium battery is used. They come as rechargeable and dry cell (i.e. non-rechargeable) versions. For sensitive devices like yours the difference is important as the internal resistance of the rechargeables is lower which affects the voltage characteristics.This meter is designed only for the dry cell version: see page 34 of the user manual, although the instructions don't make this fact clear enough IMHO. The reason for using the dry cell version is that the output voltage remains constant until the battery is nearly exhausted, but the rechargeable version starts at a slightly higher than nominally rated voltage and drifts down as the battery discharges. This means that you only get a truly accurate reading with a dry cell battery. There is no user adjustment to recalibrate the meter but you can use a different ISO rating to compensate or use the exposure compensation settings.
Apr 19, 2009 | Sekonic L-358 Flash Master Light Meter
Cameras Logo
931 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
