Question about Refrigerators
I have a fridge freezer Teka A-FC1340. Having arrived back from a weekend away the fridge part of the unit was so cold that the jug of water in the fridge door was frozen. I turned the setting on the fridge part of the unit right down and this seem to cool the temp. I then came home from work yesterday and the water in the jug was frozen again. Can this be repaired at all? and and what cost as it maybe cheaper for me to buy a new unit
  • alex_duff Mar 09, 2009
    I have defrosted the unit and then restarted it to no avail
    Serial number BC05G0E0K00BG
    pRODUCT 40634011
    mODEL A-FC1340
  • 10,515 Answers
Click the below link to get your answer
http://fridgedoctor.com/frequently-asked-questions/too-cold/too-cold.html
For future let me offer you a pdf file for other refrigerator issues...
http://static.howstuffworks.com/pdf/how-to-repair-a-refrigerator-1.pdf
Thanks.
Posted on Mar 09, 2009
  • taran_2005
    taran_2005 Mar 15, 2009
    Any further issues, you can buzz me.
    thanks.
    Sergeant:
  • 239 Answers
It can be repaired but it would cost you 65 to 85 dollars just for them to drive out to your house. that doesn't include them looking at it. it would be cheaper to just replace the fridge.
hope this helped
please remember to rate me well.
  • 495 Answers
You have a defrost problem. could be your defrost heater or your defrost thermastat
Posted on Mar 06, 2009
  • Refrigerators Master
  • 19,396 Answers
That is probably afaulty thermostat , give me the exact model number of the fridge , the one pprinted on the service tag.
Thanks.
  • Ginko
    Ginko Mar 06, 2009
    If the freezer is icing up inside, try lowering down the thermostate settings.
    If the temperature still stays too low , then you will need to replace the defective thermostate, that is not an expensive part.
    See the link below, where you can find parts, diagrams, and repair help:
    The food in the refrigerator freezes
    Freezer on Top
    Find Parts
  • Ginko
    Ginko Mar 06, 2009
    In addition, this is not the defrost system, when it is the defrost system you get poor heating and the fridge is icing up on the coils, in your case the fridge is cooling down to much.
    That means that it is either a thermostate regulation problem, or that there is a faulty thermostate.
    Regards.
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Teka freezer
need model number but most Teka models have integrated controls and a compressor system that is shared between freezer and fridge. so it looks like you cant isolate one or the other.
if you provide your model number then it might be a special case. here is user information on one model Teka.
http://www.fridge-manual.com/teka/teka-tki2-325.html
Oct 02, 2013 | Jenn-Air Refrigerators
Freezer not freezing clicking noises
Almost certainty you have a rear control board fault these boards where notorious for capacitor faults causing relays to click and water dispenser to be erratic , the board can be repaired by a confident electrical engineer or you can buy a complete unit
Mar 31, 2017 | Whirlpool Refrigerators
Water is gathering in the trough of my fridge and not draining away and pools at the bottom of the fridge. I have checked wether the hole is clear in the back of the fridge compartment, which it is. I have...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Frigidaire Refrigerators
I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
Engineer told me not to waste money calling them out again, and to buy another one...
Oct 17, 2010 | Microwave Ovens
Freezer side is cold but the fridge side is not getting cold
Luispinto243 --
The heat exchanger is in the freezer side of a refrigerator. If the cold air pathway has gotten frosted-up, or the blower is not working, the fridge side will get warm. If possible, fully defrost the unit and the frost/ice build-up will thaw-out and the fridge will start working again. Adjust the thermostat to the energy-saving position. Trying to lower the temperature will not fix the problem. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
544 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
