Question about Sony VAIO Notebook
Starting It can not start and find the SONY signal at the start
Sony kpe41mh11
The blue screen is there when there is no signal. If you connect a TV signal to the VCR, you will see that. When you start playing a tape the tape signal takes over.
Oct 21, 2013 | Televison & Video
Sony ericsson t280i mobile phone silver.how do you take the back off
hi.. can you help me? my sony ericsson t280i cellphone's can receive a signal upon start up.. then after a few minutes on standby mode, it's got no signal already... what could've caused this? hope to hear from you soon.. GRACIAS!
Jun 28, 2011 | Sony Ericsson T280i Mobile Phone Silver on...
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
Dear, when i dial a number from my sonuericsson g502 mobile, the signal strength starts falling and the communication gets disturbed...please give a solution.
Does your battery indicator go low? Sounds like a low charged or bad battery. The signal looks good until you start dialing (transmitting) then the battery voltage drops causing low signal and disruption. Try a nother battery for a test. If the unit has been dropped the circuit board is damaged but you can easly test that with a known good battery.
Aug 11, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Crackling noise at turn on
Maybe you have a really, really bad cable.
What signal are you using when this happens?
If it happens with just one signal (normal tv, dvd player, PC), try replacing the corresponding cable.
If this happens with multiple signals, I would contact my manufacturer and request a new tv, because this one is broken.
I hope you can get a new tv,
Yannick.
May 20, 2009 | Sony KDF-E55A20 55 in. LCD Television
No signal on Radio,
Start with checking the antenna has an earth connection.
Dec 06, 2017 | Sony CDX-GT210 CD Player
How to use a sony tv as a monitor?
Change the resolution on the second monitor if you ont have the 2nd monitor on your pc , Clik ON DESKTOP PROPRERTY ,SETING'S amd see the 2nd screen rezolution. and make it smaler on the second ,you will be able to keep bouth screen active the monitor and the main screen of laptop.
Jan 19, 2009 | Toshiba Satellite A15-S129 Notebook
I have a sony DSC-F717, and when i take pictues, the white colors on the image come out pink and other types the picture has like a green shadow over the picture.
Symptoms shows its start-up of CCD Imager problem in DSC-F717 and in few days, CCD Imager will not give picture data to camera circuit. CCD Imager is part which converts image in electronic signal and that signal / data goes to camera circuit for further process.
Sony will repair CCD Imager problem in DSC-F717 free of cost. Check Sony CCD Imager Support for details.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony VAIO Notebook Logo
57 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
