Question about Minolta EP4000/5000 CS/PRO Copier
Both paper cartridges malfunctioning of minolta 4000 (i dont know the solution)
  • Minolta Expert
  • 1,326 Answers
Do you see a small wrench in the bottom left corner of the displa pannel? If so press the wrench and the display will change then open and close the front door and try to open the paper trays. If it dose not work you may have more then a basic problem. Good Luck
Posted on Mar 06, 2009
Minolta EP 4000 always shows please wait after you photocopy two papers until you reboot it. and after rebooting it will still repeat thesame thing, how can i fix it please
Check fuser assembly, make sure the heater element is ok, if not replace. The thermal cut out shoul properly checked to ensure its normal characteristics.
May 30, 2016 | Konica Minolta Minolta Ep4000/ep5000...
How to fix error code C0103
one of your paper draws not working check all for proper operation might have paper behind them
Jan 14, 2015 | Konica Minolta Konica BizHub Press C7000...
Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Apr 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
I NEED THE PHONE # OF KONICA MINOLTA CUSTOMER
You can contact Konica Minolta customer care center at below details:
Konica Minolta Business Solutions U.S.A., Inc.
100 Williams Drive
Ramsey, NJ 07446
201-825-4000
If you wish to get the toner cartridge serviced or chnage it fro a new one, you can vist the below link whre you can find the information about their authorized service partner location wise.
Konica Minolta Customer Care
Regards.
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
Drawer error
on the diplay panel at the very bottom of the left hand side do you see a small little symblos (wrench) touch it the panel will go to a different display, then once there open and close the front door. its reset procedure. Next try, Open the front door youshould see a cover with a small screw, or if the cover is off, you will see two buttons, one is trouble reset the other is initialize the one to (try 1st) the left the trouble reset to the right, two draws down worked with minolta never had both draws go, make sure once the draws open check behind them for paper. Open and close front door first off also
Aug 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
Changing toner cartridges, How?
I went to the konica minolta website to see instructional video's and e-mail 'for free'
May 25, 2009 | Konica Minolta magicolor 2300DL Laser...
The problem is: Black splotch on paper
if it is a laser multi function machine, there may be toner build up on the fuser roller. also, there maybe some other component malfunctioning. i.e., print cartridge (if it's one of those "all in one" type deals", toner and/or drum (if sold separately), place a service call
Apr 06, 2009 | Minolta EP1030/1030F CS/PRO Copier
Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
Mar 21, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
May 23, 2008 | Konica Minolta magicolor 2400 Laser...
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
