Touchpad/left button not selecting
Hey there. I have an advent 7106 and all of a sudden the touchpad and left button stopped selecting. The touchpad moves the pointer fine and I can right click. It's just that I can't select normally. Is there any way I can sort this easily?
Thanks,
Brian
  • agtodd Mar 14, 2009
    I have the same problem but just the left button.
  • 271 Answers
Reinstall Touchpad drivers and then check.If you still got the same issue then call customer care.
Posted on Mar 06, 2009
It could be that the ribbon which connects the keypad to the motherboard has become loose. If you open the casing, this ribbon is a small one (the larger one is for the keyboard) and it is held in place by a small length of plastic that clips on both sides onto the connector on the motherboard. If that strip of plastic has become dislodged by a shock of some kind, then the ribbon is no longer fitted tightly to the motherboard and therefore will give you - often intermittent - faults.
Phil Frog
Posted on May 08, 2010
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
Hey i do not know how this will play out since it is sooo difficult to use my touch pad. I have a Dell Inspiron w/Vista Basic since yesterday my touchpad will not function very well. I lick my finger...
  1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound."
  2. Select the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
  3. Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity.
  4. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes.
Feb 18, 2011 | Dell F3534 Touchpad
My left button is loose and i dont no why
This is know to happen with this model Notebook. If its still in warranty contact your vendor. You can always tap the touchpad as a left click or use a mouse instead if it stops working.
Apr 15, 2010 | Advent Netbook
Advent 5401 left touchpad button broken
Had a similar problem a couple of months ago, The left button started playing up, not working with every mouse click, it gradualy got worse till it was nearly unusable.. I suspected that the microswitch under the silver button had some dirt in it. After taking a deep breath I removed the battery and the screws that hold the case lower and upper halves together and was able to seperate the case front by about 3/4 of an inch. Then using a contact cleaner Servisol Super 10 and supplied flexible straw I squirted cleaner into both mouse click buttons. After waiting for cleaner to evaporate and resecuring case halves and replacing battery I switched on .... The button works 100%..
Feb 02, 2010 | Advent Netbook
My touchpad will not respond when I tap it anymore. I have to use the left button. I used to be able to tap or double tap the touchpad and it would act like the left mouse button. All of a sudden it...
On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
THE LEFT BUTTON LIGHT STAYS ON ON THE TOUCHPAD
this is due to a faulty touchpad. it needs replacement. call the manufacturer.
Aug 04, 2009 | Advent Netbook
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Mouse pad not working
A mouse pad is a thing you put your mouse on....
now what you are talking about is your touchpad.
Check these first:
  • some laptops have a switch that turns off the touch pad (usually a button right on the topside of the touchpad)
  • did you reboot completely? full shutdown, then power on?
  • goto the device manager (with a usb mouse of course) and find the touchpad... delete the device... then reboot again it should try and find the touchpad and ask for the driver, point it to the directory that you have the driver located.
good luck!
Apr 21, 2009 | Computers & Internet
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
259 people viewed this question
David Payne
David Payne
