Question about Toshiba Satellite A60 Notebook
I got problem in connection
I have toshiba equium A200-1VO. I got problem in local area networking. Nothing is shown even I connect ethernet cable. Local area network shows that network cable is unplugged. It has Marvell yukon ethernet controller. I called my ISP for help but they told me that i hv problem in network card. But device manager doesnt show any problem. Device status shows that This device is working properly. Due to this problem, it is almost a month i hv not get connected with broadband interne. Thanking you in advance
cheers!!!
  • 1 more comment
  • WarheadsSE May 11, 2010
    The most likely culprits as I see it:
    1. Driver corruption/failure: it claims to be fine, but really isn't. A fresh copy can do wonders.
    2. Winsock stack has become a problem. Search for Winsock2Fix, as this will reset the Winsock stack (never hurts doing this anyways)
    Deciding factor : Does this happen over WiFi too?
  • Robert McCord
    Robert McCord May 11, 2010
    have you tried to release and renew your ip address?
  • Dirk1970 May 11, 2010
    does it show that local connection is disabled?
    you could also have a bad ethernet cable.
    also try to uninstall then reinstall nic device(control panel)
2 Suggested Answers
  • 1170 Answers
SOURCE: I got problem in networking
It is a general problem for all TOSHIBA laptops. Its pretty hard to detect toshiba's in network. Trying using another driver software after uninstalling the current one.
Posted on Mar 06, 2009
I have a wireless router, my vista laptop is upstairs in my room, my wireless network connection is working. but the "local area connection" says that there is a network cable unplugged. but i have...
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection" Hope that clears it up a little
Aug 29, 2010 | Computers & Internet
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Network Connections missing icon. Plus others problems.
XP tags "Local Area Connection #" with your Network Adapter. If you have a built-in LAN, it will take Local Area Conn 1" and when you disabled it and plugged in a new network adapter, it will be named Local Area Conn 2 and so on in that pattern. Your Local Area Connection will only be back when you plug the original Network adapter that XP tagged as Local Area Connection. It is not "variable" where you can choose how to name it.
Jul 31, 2009 | Computers & Internet
Mar 06, 2009 | Toshiba Satellite A60 Notebook
Dell Ethernet Network Adapter not being recognised
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
Sep 07, 2008 | Dell Inspiron 1150 Notebook
I have a toshiba Equium L300 & it cannot connect to a wireless router. I have been advised that it is missing a ethernet/wireless driver. Please advise
From what I see about the Equium, the name Equium is in use in UK only. In other European & countries USA the name is Satellite. From the specs of the model you mentioned you DO have a onboard NIC. You might have to uninstall the driver that you have due to corruption and the operating system will install a generic driver for you to use. Or you can go to Toshiba if you’re in Europe
http://www.toshiba-europe.com locate support and you can download the driver there.
If you have a driver your probably not setting (configuring the router and your computer) the network up properly.
Networking Networking: Network adapter
Wireless LAN Supported: Yes
Wireless NIC: Realtek RTL8187B
Data Link Protocol: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Compliant Standards: IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED
Jun 29, 2008 | Toshiba Computers & Internet
Toshiba Satellite A60 Notebook Logo
184 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
