Question about Simrad Tp32 Autopilot Up To 39'
Simrad autopilot getting " actuator " error message. new pump
Simrad autopilot is getting an error message " actuator " i just installed a new pump. what else could it be ?
3 Suggested Answers
SOURCE: Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Posted on Nov 08, 2009
  • 3 Answers
SOURCE: Problem: Autopilot does not
jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Posted on Mar 31, 2011
My Ap16 Simrad control head died. Any idea of as to 1) where I might get it repaired and/or 2) where I might find a replacement?
Hi John
Boy, you're up against it on this one. The AP16 is a pretty old unit for sure. Here's the link to your owners manual.
I've come across one instance in my experience where although there was enough power showing to the control head, because of corrosion and broken wire strands, there simply was too much voltage drop and not enough current flow for the unit to function when it was turned on. After cutting back/fixing the soldered connections and reconnecting the cable, the unit was good to go.
I hope this information is able to help you out.
Good luck.
-Steve
http://www.simrad-yachting.com/Root/Operator%20Manual/SimradYachting/English/AP16_OM_EN_20221560F.pdf
You MIGHT get some joy contacting Simrad tech. at 1 800 628 4487
if you're in the US. If not, here's the link to their support page.
http://www.simrad-yachting.com/en-US/Contact-Us/
Dec 08, 2014 | Navico Simrad AP16 Autopilot for Inboard...
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
jimtippettau:
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
Selenoid bypass valve has failed
Contact don@sun-me.net and he can help you.
May 07, 2010 | Simrad Ap1603r Autopilot Ap16 Rc36 Rf300...
Where can I get an installation manual for a rpu80. I am installing an AP35 autopilot on my boat but the instructions do not cover the installation of the remote pump.
I have one right here. It covers the RPU80, 160 & 300. It's $15.00 plus shipping. Call me at 410-228-7335 if you're in the U.S.
Feb 01, 2010 | Simrad AP35 GPS Receiver
Oct 28, 2009 | Simrad Boating
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Need instructions for simrad tp32
when hooked to a chartplotter, it will go to the waypoint that was marked as a goto on the plotter.
Mar 31, 2009 | Simrad Tp32 Autopilot Up To 39'
Simrad ac10 current overload
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Feb 18, 2009 | Simrad Ac10 Course Computer
Tppk26 feed circuit broke
I got Marine Superstore in Port Solent to order one for me. Your local friendly chandler should be able to order it up for you. Cost me £24 inc...
Jan 25, 2009 | Simrad Tp32 Autopilot Up To 39'
Simrad Tp32 Autopilot Up To 39' Logo
167 people viewed this question
Top Simrad Boating Experts
Michael Vincent Cruz
Steve
Steve
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
