Question about Progressive Computer JSI 6 spkr. Home Theater System with Scan DVD Player, 300W System
Does any one know how to contact the manufacture JSI
I have a JSI surround sound system and can not find a number to contact them with. The number in the manual is no good either is the web site that they post. Please help.
I have installed the z 640 but I get no sound at all
  • Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  • Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  • Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  • Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Post back!
Oct 03, 2010 | Logitech Z-640 Computer Speakers
I lost the input output wire to my surround sound for my computer
Contact the manufacturer of these speakers. Visit their website or find their phone number and request a replacement wire. I understand your frustration because the same thing happened to me. I have a Sony speaker system, and i lost the input output wire so all i did was called the company up and they sent me a replacement wire in the mail. It should not cost much at all. Any further questions, let me know so that i can resolve this issue for you.
Jan 20, 2010 | Spherex Xbox 5.1 Surround Sound System...
JSI MODEL # JS5010 sound cuts in and out when using .
Make sure it's not overheating. I have this model and know that it just has a heatsink and no fan for cooling. Make sure nothing is on top of the unit, especially blocking the vent on the right...that's the cooling vent.
Also, check your cable connections to make sure they are all connected properly.
Feb 27, 2009 | Progressive Computer JSI 6 spkr. Home...
I NEED A REMOTE CONTROL FOR MY EA-506 SURROUND SOUND RECEIVER
Many surround sound systems don't work with universal remotes. They require factory remotes. I could not find any codes either.
Contact the manufacture of the surround sound receiver, go onto there website and use the contact link. Write them asking for a new remote and they will let you know how much a replacment cost.
Feb 12, 2009 | EA Sports SRU8010/17 Remote Control
New speakers NO SOUND
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Source http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=8&p_created=1083625066&p_sid=ouvzcDmj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xNSwxNSZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1aLTIzMDA*&p_li=&p_topview=1
Dec 30, 2008 | Logitech Z-2300 Computer Speakers
JSI dvd player, remote code
I have similar problem, solve it with codes from Koss brand.
Jsi and Koss are made by same lab.
Try Koss codes, it work for me.
good luck!!
Dec 29, 2008 | Progressive Computer JSI 6 spkr. Home...
How can i plug in my logi tech speakers on my new dell computer,
  1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
Nov 11, 2008 | Logitech Z-560 Computer Speakers
No sound from speakers at all
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 24, 2008 | Logitech Z-5500 Computer Speakers
No sound from logitech x-230 subwoofer
Try the following steps:
Apr 17, 2008 | Computers & Internet
JSI js5001 Home Theater
My dvd player won't go on. Worked one day the next day wouldn't work any help?
Jan 05, 2008 | Progressive Computer JSI 6 spkr. Home...
51 people viewed this question
Top Progressive Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Progressive Audio Player and Recorder Expert? Answer questions, earn points and help others
