Question about Maytag MER5755QAS CleanDesign Electric Kitchen Range
MAYTAG PERFORM OVEN DOOR,THE HANDLE IS COMING OFF. HOW DO YOU GET THE DOOR APART, TO TIGHTEN IT BACK.
    President:
  • Maytag Master
  • 2,651 Answers
In your user guide it explains procedure to remove the door, after emoving the door and layingit flast on conter /table ita amtter of removing sccrews holding on glass, and top trim to get to the screws that holdon hanlde, a little patience is all thats required not hard here
Posted on Mar 07, 2009
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
How do I tighten the door handle on my maytag oven
Yes you need to take the inside of the door off. Usually a few screws. Then you will have access to the screws that hold the handle.
Jan 14, 2015 | Ovens
I have a loose door handle, how do i fix it? Do i have to take the door off?
Hi You will have to open the oven door and take the screws out of the side that faces inwards to the oven. Once the screws are removed the door will come apart. And then you can tighten the screws to secure the handle better. Also before you do that look under the handle and make sure there are not any set screws in it that tightens down to an anchor. They usually will be hex or allen screws .
Dec 16, 2010 | Magic Chef CER3760 Electric Kitchen Range
Handle on oven door is coming loose; how do we access the screw in order to tighten it?
can the inside skin of the door be removed by unscrewing screws?If so, this should access the screws for the handle...be sure to replace any insulation properly.
Mar 06, 2010 | Kitchen Ranges
Oven Handle drops off of door
Whatever keeps the handle on is not working. Most oven handles are held on by a screw on each end. It can be tightened from the inside of the oven door. If you don't see the screws, you may have to take the door apart. Buy some longer screws if needed.
Nov 03, 2009 | Kenmore Ovens
The oven handle to our Maytag stove is off on the right side, How do I get inside of the door to repair the handle? There is no selection for the stoves so I just picked one.
not an easy fix but look for screws or nuts on oven door sides carefully unscrew door should come apart to get to handle to tighten or replace bolt or screw or nut
Aug 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Aug 22, 2008 | Maytag MER5775Q Electric Kitchen Range
Fixing a door
I took other hinge apart.
Removed front glass by removing handle -bar.
Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly.
Removed control panel assembly by taking out 5 screws.
Started with one side hinge first.
Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside.
With the same screwdriver engaged a little hinge to the notch of larger arm..
Did the same thing for other hinge.
Put the upper screws back,
Tightened bottom screws back.
Put the front glass and handle-bar back.
Put control panel assembly back.
Now it is ready to go.
Door is Fixed.
Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
May 09, 2008 | Cadco OV-250 Electric Single Oven
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Maytag MER5755QAS CleanDesign Electric Kitchen Range Logo
372 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
