Question about Yamaha RX-V800 Receiver
Front Display Panel Letters are Scrambled and Cannot Be Read
The Front Display Panel is working. However, the display letters/characters (the letters that change and describe the settings, volume, etc.) are completely scrambled. Thus, I do not know what setting the receiver is in or what it is doing. Also, a the digital display of the volume bar is fully illuminated, but missing a bar or two. Front Display Panel Letters are Scrambled. Could this be caused from an electric shock? Three weeks ago, I hooked up a pair of Klipsch floorstanding speakers using Monster brand speaker wires. I have been enjoying this receiver for years w/o any problems.
  • seabasstt Mar 12, 2009
    Thanks for the reply. I've already tried that but didn't make any
    progress. A couple of days ago, I dropped it off at a friend of mine
    who is an "audiophile equipment repairman". When we find out what's
    wrong, I'll post the solution. Maybe this will help the other fellow.
    thanks again
  • 336 Answers
Could need to be reset. Try unplugging it for a couple of Min's. it may reset itself. If not send me a message and I'll check the service manual for the reset procedure on Monday when I go to that hell they call work.
Posted on Mar 06, 2009
How do i change my phone from numbers to letters
I am not sure about the brand & model number you are using. But in NOKIA phone you need to PRESS # for more than 5 Seconds then it will change to letter, word & vice versa.
Oct 17, 2010 | Lands Phones
My Nokia E52 wont display chinese characters
hi i hv nokia e52, i am getting display as letters coming bold i try to go ctrl.panrel to treat this prob.but i am getting same.
May 12, 2010 | Nokia E52 Smartphone
How do I chance the names on an NEC phone
NOTE: Display Dterm
A name with up to 16 characters can be entered to display the name on
other Dterm telephones when making a call.
• Press Speaker key, Receive dial tone.
• Dial the Name Assignment access code and receive special dial tone.
• Using the keypad, depress the key with the desired letter to display the
first letter on the key. The
display will indicate the
numerical designation.
Subsequent depressions will
advance through the letters
on that key. The Dial Pad Key
TABLE can be used as a
guide to indicate the key and
the number of depressions required to display numbers, letters, spaces
and periods.
• When the desired letter is displayed, depression of the Transfer key will
change the letter to a lower case letter (default is upper case). Depress
the Hold key to enter that letter and advance to the next entry.
• Repeat the previous two steps until the desired name is displayed and
Apr 05, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Having troubles typing. Wrong characters com up...symbols display instaerd of letters. I did something.
just check the either ur keys wil be misplaced or goto keyword through control panel n edit the keys
Jun 03, 2009 | RIM Blackberry 8700c
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Enter passwork - 0000 is default
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Did you try uninstalling and reinstalling? Sometimes that's best.
Jun 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
No LCD Display
they can fail try writing a letter to the manufacturer,if there a good company the will help.
Feb 11, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
VEERY big letters in some websites
go to START, CONTROL PANEL, DISPLAY, SETTINGS. There's a slider for screen size set to 1024 X 860
Sep 24, 2007 | Dell Latitude C400 Notebook
Yamaha RX-V800 Receiver Logo
127 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
