Question about SAMTRON 55V 15" CRT Monitor
OPEN A BACK COVER ON MONITER
NOTHING
  • 530 Answers
Hi im josh try this solutions of mine. Monitor Problems:
THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
- Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician.
COMPUTER BOOTS, BUT DISPLAYS “JUNK” ON THE SCREEN
- It may be that the display card is defective. Try a different card. If it works the first card may be bad.
- Try the suspected bad card on another computer. If it displays the same thing it is conclusive that the card is bad.
DISPLAY IS DIM, OVERLY BRIGHT, OR BLURRY, OR UNPLEASANT.DISPLAY IS OFF CENTER. LEFT OR RIGHT SIDE OF MONITOR IS OBSCURED.
- Try adjusting the control knobs located on either the front or back of the monitor. It maybe necessary o open the monitors casing to get the proper adjustment controls. In this case be very careful because there are high voltages in the monitor.
THE VIDEO DISPLAY FADES AND BRIGHTENS, OR IS WARY.
- The voltage may be fluctuating due to so many appliances or electric devices on he same branch circuit.
- Turn off other appliances and peripherals, such as printers, external modem, refrigerator, microwave oven, transformer, etc. and see if that solves the problem. If the problem persists, try swapping out the display cards. If changing the monitor solved the problem, repair or replace the monitor.
IMAGE IS NOT STRAIGHT ACROSS THE SCREEN
- If the monitor is still under warranty, bring it back to the dealer for adjustment. If the you want to do it your self, bare in mind that this is potentially dangerous procedure because it must be done while he monitor is on and there is very high voltages around the picture tube.
WARNING: THIS IS A DANGEROUS PROCEDURE!!!
- Open the monitor casing and loosen the clamp holding he coils around he picture tube. You can loosen them (usually there’s a wing nut) and a rotate the coil assembly until the picture strengthens.
good luck please vote
Posted on Mar 06, 2009
My hp moniter is not working after a thunder in the night
Monitor is defective,First of all replace a.c lead (mains cord) If monitor does not on remove back cover (but it can be dangerous voltage stored in power supply) and check fuse if open replace with new fuse.After replcement fuse monitor is off power supplycan be defective.consult a qualified Technician .
Dec 04, 2011 | HP L1706 17" LCD Monitor
Moniter not rebooting when pc is switched on
Check the pins in the monitor that plugs up to the back of the computer and see if they are bent.
Apr 27, 2010 | Acer Aspire M1641-U1521A PC Desktop
How to open back cover of samsung 55v moniter
Read somewhere that you need to insert a blunt screw driver in the slots between the cover and the the top of the front cover and press down lightly. hope this helps...
Feb 01, 2010 | SAMTRON 55V 15" CRT Monitor
Open the back door
remove all screws at the back. and unlock all snap lock at the back cover.
May 30, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
How do open the back door
remove all screws and unlock all snap lock of back cover.
May 30, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Proview Monitor pic quality diminishing
It sound to me as if the focus on the moniter has changed. If so a couple of possible tihngs might be going on. You could have a dust build up due to the static charge difference the dust and the high voltage potential with in the moniter. If so you can open it up and clean it with an air sorce or vacumn. You might also try adusting the focus adjustment on the back of the moniter. The worst case is that some componet is becoming weak and will fail in the future. Good luck
budman630
May 14, 2008 | Gateway FPD2275W LCD Monitor
No power on moniter
hi,
is the pilot light, light up ?
Apr 01, 2008 | Computers & Internet
Blank screen
hi i am kishan, from india u r facing this problem so same problem is facing my customer so i think its problem of your lcd so u can do one thing \ back side of your laptop u will find vga port so do arrang one moniter(desktop) and attach it to your laptop vga port and then start your laptop and press alt+f5(simbol of external monitor) and u can dispay your windows on moniter now u can take your backup it will work but u shoud check your laptops lcd dispay regard .... take care
Jan 20, 2007 | Compaq Armada E500 Notebook
How to open moniter cover
see on the top of cover where have two hole,leave monitor on it face, unwrap two vit on it back . you can use a small knight to push on it strongly and slowly keep going untill you hear a sound it leaf connect lock on cover monitor. do again with other hole
May 05, 2006 | Samsung 793DF 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
100 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
