Question about Microsoft Visual Basic 6.0 for PC
How do i use date in visual basic 6
I am using Access as data base there is a date field
In vb i'm passing to dates in two text box and want to get data which lies between these two dates
since dates in SQL command are of string type and date in access are date type
there is data type mismatch
pl help and solve my problem
Murtaza Aalam
  • 1 more comment
  • Anonymous Mar 20, 2009
    there is a date/time field in access now i want to get those records which lies between two date e.g those records which lie say between 01 march 2008 and 18 august 2008
    my problem is that when i execute SQL command in VB 6 with two string type in a text box . It shows an error i.e Data type missmatch
    hope now i'm have explained my problem more clearly
    Murtaza
  • Anonymous Apr 01, 2009
    Sir,
    I am creating a project in vb6.0 using acess database i have added search option there also ex search by date or name, etc
    My problem is that i want to search records in my database between two dates and have a report of same for print
    if you can solve this problem then please mail me its solution at aakash.best@gmail.com. (Mail me an example file of same in vb 6.0 and acess databace 2000)
    you can call me also.
    i will be very grateful to you
    reply me soon as possible pleasee.
    Akash Garg
    9968635587
  • Anonymous May 20, 2009
    I am using vb 6.0 and MS-Access 2003 as data base. I want to call data between 2 dates on the Datagrid view placed on the VB Form. I am using ADO control. Please Help in this regard guruji
    Dedicated:
    Visited the website for 20 consecutive days.
  • 90 Answers
I am not getting your problem clearly.
If you are referring to save the input dates as date in database with the help of sql query then you need to provide hash(#) mark at the beginning and end of date values. It will resolve your problem.
Hope this helps and let me know if you are not getting the solution clearly.
Thanks.
Posted on Mar 18, 2009
I dont know the disadvantages of visual basic.
visual basic, is only a basic programming language, most programs will run on Java script, microsoft is visual basic though, but it uses a lot more complex scripts then, if you like the programing language, go for it, but i did not like it.
Also
VB is undoubtedly the simplest and easiest platform to build major Windows applications. The problem is that like other Microsoft products they change faster than I change my socks.You will certainly need more than just VB. Get into server and client side scripting and the use of VB Net.
Jul 06, 2010 | Microsoft Visual Basic V6.0 Fundamentals...
How to make a code for log in using database?
RIGHT CLICK ON MY COMPUTER AND SELECT THE MANAGE AND SELECT USER AND GROUPS CLICK YOUR USER ON WHICH YOU WANT CREATE PASSWORD RIGHT CLICK THE USER AND SET PASSWORD AND FILL THE PASSWORD AND ENTER NOW YOUR PASSWORD WILL SET ENJOY
Oct 21, 2009 | Microsoft Visual Basic 6.0 for PC
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
VB With MC9090S
If you are willing to use VB.NET, then it will be easy. You would need the Symbol EMDK. With that and VS2008 (Express should be fine as well), you only need few coding steps:
1) Add reference to dlls
Symbol.dll and Symbol.Barcode.Dll
2) Finder a scanner
s = Symbol.Barcode.Device.AvailableDevices.First()
3) make a reader
r = New Symbol.Barcode.Reader(s)
4) add data
d = New Symbol.Barcode.ReaderData(1, 1024)
5) enable laser
r.Actions.Enable()
6) enable reading
r.Actions.Read(nrd)
7) add handler
AddHandler r.ReadNotify, AddressOf r_ReadNotify
8) read data in event
msgbox(d.Text)
That is all there is too it. Good day.
Jan 22, 2009 | Symbol MC9090 Barcode Scanner
Code for find the Ms access database size using visual basic
The way to get the database size is to point to the directory that the database is do a DIR statement with an output to a file as in DIR payroll.mdb>dbsize.txt and then read from the text file, the first field of the second line being the name (which you really don't need) then the size value of the database.
To import the text files using VB 8 use
'Imports System.Data.OleDb Dim conn As New OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0;Data Source=d:\path\filename.mdb") Dim cmd As New OleDbCommand("SELECT * INTO [import] FROM [Text;Database=d:\path;Hdr=No].[dbsize.txt]", conn) conn.Open() cmd.ExecuteNonQuery() conn.Close()
Nov 10, 2008 | Microsoft Office Standard for PC
Visual basic codes
Since I'm not sure what version of VB you are using, or whether you have a date picker application or not, try the following suggestions:
Nov 06, 2008 | Computers & Internet
How this can be do in asp.net???
You will need a third party control to produce graphs in ASP.net. Is that what you want?
Take a look at http://www.dotnetcharting.com/ it is free I think and may do what you need.
Nov 04, 2008 | Keystone Active Server Pages (ASP)/Visual...
Visual basic
Please Check the format of date time that is comming from record set
Aug 02, 2008 | Computers & Internet
Vb project
One of three ways:
1 make the table using vb creating a Bload screen.
2 using the visual data manager.
3 import a windows access or excel data base table.
Try the data wizard, easiest to use and U can program the program to manipulate the data in the tables.
May 29, 2008 | Computers & Internet
Ms access
Stored Procedures don't exist in MS Access. You do have the following options though. Queries, which are just select or action queries. VB Code, which you can write using Query Objects as if you were writing a Visual Basic application. These can be Functions or Subroutines. In these, you would use the standard programming techniques with while and for loops, etc.
You can create complex situations combining the two of these. A function in the VB code area can accept through parameters, the single values (line by line, record by record) in a query and act on them and manipulate the values.
For example: create a query that does a select phone from address. Create a function in vb called public function StripDashesInPhone(Phone as string) which then uses VB coding to strip dashes from each phone value passed in. To make it all work, in the query on one of the field columns put "NewPhone: StripDashesInPhone([Phone])" and for every record processed in the query, the function is called with the [Phone] field value passed in to the function and the action is processed and returned.
Other than writing a function that is activated by a form button click, which opens the current db and opens a table and process it, just like in VB, this is about as close to cursors and oracle procedures as you get.
I wish it was more, but ...
Oct 09, 2007 | Microsoft Office Standard for PC
Microsoft Visual Basic 6.0 for PC Logo
451 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
