Question about Sony Televison & Video
Powers on only sometimes / red standby light blinks
It blinks 7 times the only information i could get is possable high voltage shutdown over33k power supply reg and horizontal circute. also (h stop) no raster check 515 & 516 &jungle ic, ic206 but could not pull up info to explain what that means
  • 4,234 Answers
If you actually have a flat panel set, then the "fix" you list is not applicable. Those are for a standard CRT based Sony set. Can you please post the make and model of your unit. We can then look up the diagnostic code and provide you with a proper diagnosis and solution.
Thanks,
Dan
Posted on Mar 06, 2009
Tv won't turn on
High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. 7 blinks to standby light indicates this. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 21, 2013 | Televison & Video
No Picture and Lttle red light next to power buttons blinks for about 30 seconds
First thing to do is reset ( see link below) and see if it resets otherwise if problem continues it will need some work
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. There are some common breakdowns in the High Voltage circuits in this set. One is the flyback transformer. Another is a small high voltage capacitor in the sweep corrction circuit. There is a cap that goes open in a high voltage circuit (C6532) which needs to be replaced.
Support bulliten by sony
Thread on your model
Nov 20, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Sony trinitron standby light blinks 7 times. no picture. light continues to flash. tried hard reset. no picture. model sony wega kv-36hs510.
To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
Sony Trinitron, KV-36XBR400 standby blinking light cannot power on. test it three times. first time, blinking 7 times, second and third time, blinking 5 times. bought it second hand two weeks ago...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33kV and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Feb 23, 2018 | Televison & Video
Our tv turns off as soon as we turn it on. the red light blinks 7 times
Seven blinks = High voltage shutdown (overcurrent protection). The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits, otherwise send the TV to a workshop for a quote on likely parts and labour costs, then make a decision afterwards about whether it is economical to repair or not.
Usually it is either the flyback transformer, the tuning capacitors in the collector circuit of the horizontal output transistor(s) as well as the transistor(s) which could be faulty. These parts should be replaced at the same time.
Short-circuit horizontal output stage - hence the 7 blinks error code from the standby LED.
Mar 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The tv standby light blinks 7 times then repeats. What do I do?
Dear John,
Welcome to Fixya
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. I think it helps
Chandrashekhar
Dec 27, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Standby light blinks 7 times and tv will not turn on
Thanks for using FixYa. Standby light blinking 7 times means high voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. You’ll need to check power supply regulation and horizontal circuits. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 12, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The standby botton blink 7 in my sony trinitron
May 07, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Auto shut off
Nov 24, 2008 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
