Question about Canon Office Equipment & Supplies
Have canon mf5700 says check paper size. Powering off doesn't help Changing trays does not help. After powering on again it prints a test page and then gives the warning again.
You need to remove paper tray, and unplug canon. Leave it this way overnight, and in the morning, reinsert the paper tray, and plug back it. This should effectively reset the machine, and clear that error. It worked for me!
Posted on Jul 25, 2009
Cannot print Legal size on Canon IR2420L
LEGAL SIZE IS LGL THAT MEANING 8.5/14 INCH. IF YOU WANT TO PRINT CHECK THE SIZE OF THE PAPER, FLSC IS EQUAL TO 8.5/13
Apr 22, 2014 | Canon Office Equipment & Supplies
When printing on the 4250, the margins are moved to the right of the paper cutting off the text. This is an XP computer and the PCL and PS drivers have been tested...
I would check to make sure that the paper trays are set properly and paper size is being detected properly. Print out the configuration page and see if that prints correctly. If it shows the same shift in image, check the paper sizes that the configuration sheet shows to make sure it is reading the trays properly. If the trays are reading properly and test print prints properly, then it is either your driver or the software you are printing from that has a problem.
To print the configuration sheet, press the down arrow button until the screen reads "information", press checkmark and then use the down arrow until "configuration page" is highlighted and then press the checkmark again. After a few seconds your page will print.
Apr 27, 2011 | Office Equipment & Supplies
Printing but page comes out blank
To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. First, check the ink levels. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
If not, try to restart the printer. Restarting the printer might clear the issues and allow the printer to function correctly again.Press the power button to turn-off the printer then unplug the power cord from the back of the printer, and the USB cable(if connected). Leave unplug for 30 seconds then reconnect the USB cable and the power cord.
If issue persists, try to reboot your computer. Restarting your computer might resolve the issue. If the printer prints all pages correctly, but it adds blank pages to the printout, check for blank pages in the print preview.
If the preview contains no blank pages, check the printer cables. If the printer connects with a USB cable or an Ethernet cable, a faulty connection might cause the issue.
If the issue persists, check the printer settings on the computer. Issues with the printer settings on the computer might cause the issue. Follow these steps to check the computer: Step one: Check the default paper settings. Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)).Follow these steps to check the default paper settings.Click Start then go to Printers and Faxes .Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences . Under Printing Preferences window click the Features tab. Compare the settings in the Size drop-down menu with the paper in the tray. If the size of the paper in the tray is not the same as the setting in the Size drop-down menu, change the setting:Click the Size drop-down list, and then select More . The Size is window opens.Select the size of the paper that is in the tray, and then click OK .Click OK in the Printing Preferences window, and then click OK in the Properties window. Step two: Print a test page A test page might help determine if the printer installation caused the problem.Click Start , and then click Control Panel .Right-click the Printers and Faxes folder (c01532297.gif ), and then click Open.Right-click the printer icon (c01532298.gif ).Click Properties .In the General tab, click Print Test Page . The printer prints the Windows XP Printer Test Page.If the Windows XP Printer Test Page prints successfully, you do not need to continue troubleshooting.
If the page is blank, print from an alternate program to determine if the current program is causing the issue.Browse to the location of your saved document, right-click the file, and then click Open With .Select a program other than the program you are currently using to print the document.Open the file in the program, and then check the contents.(Most files open in plain text applications, such as Notepad or WordPad, even if the contents include unusual symbols or text that does not make sense). Try to print the file. If successful, the printer prints exactly what displays in the program window. If the document prints successfully in the alternate program, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance. If the document still prints blank pages in the alternate program, disconnect other devices. Other connected devices, such as scanners, MP3 devices, or other printers might cause conflicts in the communication between the printer and the computer.
If the issue persists, go to this link for the rest of the troubleshooting steps. Go directly to solution nine. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&cc=us&lc=en&dlc=en&product=3390949&tmp_track_link=ot_search#N46
Apr 03, 2011 | HP DeskJet F4280 All In One Printer InkJet
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
Jun 12, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
"always getting check paper size"
the paper size you are using is incorrect.
1- when you take out the tray is the the paper snug in the tray? is the paper adjuster set to LETTER, is there a switch for custom and letter? is it set to letter?is it set to letter in the menu?
Dec 08, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
Oct 16, 2007 | Canon imageCLASS MF5730 All-In-One Laser...
242 people viewed this question
old marine
old marine
