Question about HP DeskJet 1280 InkJet Printer
I just fix in new black and coloured cartridges and only black and red colours appear on my prints. the replaced coloured cartridge was giving similar print problems.
  • 530 Answers
Hi im josh in cebu phils. friend may i help you? it happen try to shake the cartridge that doesn't print.and install it again and just remember this: Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge. so thats all good luck
Posted on Mar 06, 2009
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
HP DeskJet 850c will not print colour
It could well be the printer head (the area where the cartridge locks into the printer) has gummed up contacts. Take a soft, lint-free cloth and wipe down gently wipe down the face of the contacts. Keep wiping until all residue is removed. Reinstall a color cartridge and then run the printer's software alignment utility (this is part of the software that comes with the printer).
Aug 27, 2009 | HP DeskJet 850C InkJet Printer
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Can't print just black when out of color with Samsung CLP-300
its not possible till you get that rec colour refilled in your colour cartridge or replace the colour cartridge.so you cannot print black as the printer is not been able to end its cycle as the cycle is getting break at the colour cartridge.its very common problem faced by many users but no other option except replacing or refilling the cartridge.
thanks.
Dec 14, 2008 | Samsung CLP 300 Laser Printer
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
LexMark P6350
go to---- lexmark solution center option ---- by clicking the ---printing preferances option ---- in that select the ---new cartridge installation option or change cartridge option---- in that option you select the proper number of your cartridge and it will ask whether it is new or old let the cartridge refilled or used or any you should always select the option new cartridges.then it will detect the cartridge and u will be able to print the colour from the cartridge.
Sep 24, 2008 | Lexmark P6350 All-In-One InkJet Printer
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printing colours
The color cartridge is faulty, you need to replace it.
If it is new ask a refund.
After putting a good cartridge do head cleaning.
Sep 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
Aug 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP DeskJet 1280 InkJet Printer Logo
175 people viewed this question
Ben Johnson
