Question about Firstwheels City Elite Standard Stroller
Firstwheels harness I have purchased this pram in rebel red but it has no harness pads on the shoulder straps. Does anyone know where I can get them?
To be honest i wouldnt bother buying the first wheels ones. They are very big and bulky should straps. I would reccomend buying some strap covers in black of ebay as they would be alot more comfortable than the first wheels. I took mine off and used some smaller mamas and papas ones. Hope that helps you
Posted on Jun 28, 2009
Adjusting quinny buzz harness for a newborn
Hi
This is not feedback we've heard before! Remember there are two places to adjust the harness - underneath the shoulder harness pads and at the waist position. To adjust underneath shoulder harness pads you need to undo the popper from the harness, slide the pad down the length of the harness and adjustment point revealed to make harness smaller.
Jan 03, 2012 | Quinny Buzz Jogger
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
The shoulder strap adjustors (the things that make the strap longer/shorter) on my Bugaboo Cameleon are easily pulled down by my 2 year old. He is then able to get out of his harness & out of the pram....
No that should not happen. Bugaboo have very good customer service while in the two year warranty period that all turns to custard the day after it expires, So contact them now!
Sep 01, 2011 | Bugaboo 'Cameleon' Stroller
How do I tighten the straps of my Quinny Senzz pram? My baby is 7 months old and the pram straps are loose when i place him in the pram. is there anyway, I can tighten the straps for a more snug fit? When...
Good Afternoon
Go to www.quinny.com and select the country you're in; You can then view the Quinny Senzz model and download a replacement instruction manual which will show how to adjust the harness. If you're not sure, visit your local Quinny retailer and ask them to demonstrate for you.
Jun 14, 2011 | Quinny Senzz Stroller Star
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
Quinny harness pads
Hi if you bought buggy in 2007 contact dorel with proof of purchase they will send you new extensions & an xl seat cover. They also can supply the harness pads but you can pick them up cheaper on ebay.
Apr 23, 2010 | Quinny Buzz Three Wheel Stroller
Ive no over shoulder straps
You can purchase a replacement shoulder harness by visiting your local stockist or by contacting Bebecar direct on 01692 408807. You can find you local stockist by visiting the Bebecar website http://www.bebecar.co.uk/stockists/stockists.htm
Feb 25, 2010 | Bebecar Raider AT Stroller
Hi there. i have purchased the frootmuff for quinny and there is no instructions. im not sure where the straps attach to on the top and there is 2 slits for the soulder straps to go through when i can only...
the first large hole to the bottom of the footmuff is for the **** pad you will then need to remove top section of straps from the pram which is a slide clip then remove the strap covers at this point you can push the straps in the two lower slits at about bottom height then you will need to put the strap covers back on then fit through either the first or second slits in the cosey toes (depending on height of child) attching he straps back to the pram and you are ready to go also most quinny prams have 2 levels which the shoulder straps can be attched i hope this helps x
Nov 23, 2009 | Quinny ZAPP Stroller
How to fit the quinny sleeping bag?
If you unstrap the harness at the shoulder pads, you can then pull the whole strap through sleeping bag and push the bottom part through the hole on the seat, then reclip through shoulder pads.
Oct 16, 2008 | Quinny Buzz Jogger
Fitting quinny footmuff
hey it took me a while to figure it out, at the top of the padded shoulder straps at the back if you feel with your fingers you will find a popper fastening you have to pull it so that it comes away then you should be able to find that the harness is attatched by a loop, take that off and then with the harness unattatched you can thread the slits of the footmuff through and then reattatch it all including the padded shoulder straps, i took mine apart today because my daughter has outgrown the comfort cushion so i took it off after realising there was a bigger seat unit undernath it i bet not alot of people know you can do this, anyhow, by adding the footmuff it makes it alot more padded and cosyier hope that helps!
Mar 15, 2008 | Quinny Buzz Jogger
Firstwheels City Elite Standard Stroller Logo
214 people viewed this question
Top Firstwheels Baby Gear Experts
Dorel UK
Dorel UK
Are you a Firstwheels Baby Gear Expert? Answer questions, earn points and help others
