Question about Dewalt Versa Clutch Tek Screw Gun DW268
No power dw268 tech gun
6 months old and nothing happens when i press trigger fwd or rev. power lead iso.k. as have tryed 2 seprate leads to no avail
    Problem Solver:
  • 8 Answers
One of the brushes is most likely stuck in it's holder and not making contact with the commutator
Posted on Oct 29, 2011
  • 2,176 Answers
I would take this back for warranty repair, Dewalt has a one year warranty on their tools. If that is not an option get back with me on the exact model and type number and I will look into it further
Posted on Mar 22, 2009
How the i put the timing right
Attach the spark lead to the number one spark plug.
If the timing light is a powered type then
Attach the power leads of the timing light to the battery - red lead to the + terminal on the battery and the black lead to the - terminal on the battery.
Loosen the distributor so you can adjust the timing, start the engine and press the timing light trigger and aim the timing light on the timing marks on the crankshaft pulley. Adjust the distributor to the recommended timing mark for your engine.
Turn off the engine, remove the timing gun and tighten the lock on the distributor.
Feb 24, 2012 | Mitsubishi Eclipse Cars & Trucks
How do I set the time
CLICK HERE for your user manual.
You can save or print it for further reference.
Setting the clock is inside. (page 6) as follows...
Setting Clock Time and Calendar
Important - While setting the time or calendar, if you do not press the appropriate buttons
(as explained below) within approximately 8 seconds, the display will stop flashing. If this
happens you must follow the instructions again from step 1.
Setting the Clock Time
1. Press and hold the Time Set Button until the display begins flashing.
2. Press the FWD/Month or REV/Date Button to select correct time. Remember to
set the correct AM or PM. The PM Indicator is located on the upper left side of the time
digits (there is no AM indicator).
3. Press the Time Set Button again to return the display to normal mode. You can also
allow the display to flash for approximately 8 seconds to return to normal mode.
Note: While setting the time, if you press and hold the FWD/Month or REV/Date
Button the minutes will begin counting at a moderate pace, then get faster. This will
assist you in easily setting the time quickly and accurately.
Thanks!!
Sep 30, 2010 | Timex T158W Clock Radio
My computer has been working fine for the past 4 months onlu y for me to put it on and this happens it restarts itself every 4-5 secs and this goes on until i press down d power button.i have tried...
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Sep 10, 2010 | Gigabyte GA-EX58-UD3R Motherboard
Power supply does not start when ON button is pressed. 5 boards involved, with different power supplies, memory and CPUs. Followed Intel's Troubleshooting Guide (Rev. 1.0, April 2002). Replaced CMOS...
good luck
Sep 08, 2010 | Intel S845WD1-E Motherboard
Breaker blow
You may have a short in the trigger leads that is pulling the weld current back through the leads and through the control cable. The short could be causing the breaker to blow. Can you open up the gun handle (disconnect it from the power source first) and check your trigger leads for cuts or nicks. Also check the outer jacket of the cable for cuts which may be deep enough to allow the current carrying copper to touch the embeded switch leads.
Apr 21, 2010 | Hobart Handler 125 Ez
What are the trigger electrical connections for the CID-1802P cordless drill
as you look at the side of the switch, the black lead is top left, the white lead underneath it, and the two reds from the right side.
the white lead and thinner of the red leads should go to the led. if you are looking at the back of the motor as it will sit in the housing, the black lead should go to the left side and the red lead should go to the right.
if you get them backwards it shouldnt matter for the motor although it may make the switch function opposite (i.e. impactor spins rev in fwd and vice versa).
the two wires from the battery tabs plug into the bottom of the switch. again, reversing them will at worst cause the switch to operate opposite function.
Nov 02, 2009 | Ryobi 18v Variable Speed Impact Driver...
Need help to reconect power cord to my dw268
If you go to the Dewalt service center online you will find an exploded view diagram of your tool, and usually an owners manual as well. Try this link:
http://www.dewaltservicenet.com/SearchResults.aspx?q=DW268
I hope this helps you to sort it out. Good luck!
Mar 22, 2009 | Dewalt Versa Clutch Tek Screw Gun DW268
Tips are corroding & disappearing
That is normal for a soldering gun especially if you are using acid core solder. I do a lot of soldering with rosin core & have to change the tip about every 6-8 months. Just get a couple of new tips. Rick
Mar 06, 2009 | Black & Decker Black Decker Dualtemp...
Dewalt Versa Clutch Tek Screw Gun DW268 Logo
154 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
