Question about Philips GoGear SA3245/37 Digital Media Player
My GO Gear not starting
I use a Philips Sa32XX 4Gb version go gear . I now have a trouble with it as it is neither being detected in a PC nor it is starting . When I ON it Philips Logo appears and later it turns OFF. When I checked in the device manager on connecting the device to PC I found this message
 "This device cannot start. (Code 10)
Click Troubleshoot to start the troubleshooter for this device." So If Any one know how to solve it please help me.
  • 2 more comments
  • dattut Mar 07, 2009
    yes itried it but it doesnt solve my problem
  • chaoticnight Mar 12, 2009
    No it doesn't work when u do that
  • Anonymous Mar 19, 2009
    this product sucks big time.. no wonder they sell it for cheap
  • Anonymous Apr 01, 2009
    my player doesnt charge at all
  • 22 Answers
Did you try pressing the reset button on the bottom of the player next to the hold switch?
Posted on Mar 07, 2009
The computer can not see the philips player philip moldel go gear aria 4 gb
Have the go gear plugged to another PC to check if the player is detected. If so the PC is having errors and must be scanned for virus or restored to an earlier date.
Also check to see if the go gear is infected or has faulty files in the memory. If so have the files delected off after scanning, format and reinstall files with the help of the philips media convertor.
Oct 23, 2010 | Philips GOGEAR SA6045 MP3 Player
My philips go gear 4GB wont turn on even though it is charged
There is a small hole on the side of the player through which you need to use a small office pin to reset. press it for some 5 secs and release. the playerr would have hung up earlier and is now reset. you can now switch it on. Hope this clears. Good day
Jul 02, 2010 | Philips Electronics - Others
Code PO732 2004 Ford Expedition
Trouble Code: P0732 (4.6L V8 VIN W Auto)
Incorrect Second Gear Ratio Print this code dataprint_icon_codes.gif Number of Trips to Set Code: 2
OBD II Monitor Type: CCM Details
Indicators: MIL Details
Trouble Code Conditions:
Engine started, vehicle operating with 2nd Gear commanded "on", and the PCM detected an incorrect 2nd gear ratio during the test.
Possible Causes:
  • 2nd Gear solenoid harness connector not properly seated
  • 2nd Gear solenoid signal shorted to ground, or open
  • 2nd Gear solenoid wring harness connector is damaged
  • 2nd Gear solenoid is damaged or not properly installed
Refer to the mechanical section to diagnose transmission concerns
Trouble Code: P0732 (5.4L V8 VIN L Auto)
Possible Causes:
Refer to the mechanical section to diagnose transmission concerns.
Oct 26, 2009 | 2004 Ford Expedition
I use a Philips Sa32XX 4Gb version go gear . memory full and ...
I just managed to get this problem worked out, added a bunch of music then it would just freeze up while it said "Updating." I finally got Windows to recognize it by plugging it in while starting up the computer (dumb luck), just plug it in right after the first Windows screen shows up. Not sure why it worked, but it worked twice for me. Once I got Windows to recognize it I could finally go in and delete a couple things to make space for all the system files the thing needs to run. At that point the Philips device manager also recognized it, and let me repair it (at this point it will tell you to unplug it, then hold down the back button, plug it in, and don't let go of the back button until it tells you to). Might also try the hold down the back button and plug it in trick first to see what it does, it might just work that way too. At any rate, make sure there is some free space on it before you unplug it and try to use it, otherwise I imagine it will mess up again. Also, to note, mine said the firmware upgrade failed, but everything works fine. It took quite a while for it to update after I unplugged it, but I guess that is normal. Best of all, I didn't lose the rest of the stuff I had on there!
Jun 02, 2009 | Philips GoGear SA3245/37 Digital Media...
Go gear sa32xx
You have to use the Philips (Arcsoft) Media Converter to convert/transfer videos. If the converter is not recognizing a specific video type - FLV, for instance - download a free program called Riva FLV Encoder and convert the videos to AVI format first. Then the Philips Media Converter will recognize them.
The Philips Media Converter is not capable of converting an entire DVD - you will have to acquire video editing software, and then break up the DVD files into 15-minute chunks, and then convert each chunk.
If you are getting a codec error, do a google search for free video codecs - they are out there. Windows Codec Pack and downloading the latest version of quicktime will give you most of these needed codecs.
This player is not capable of playing copyright-protected videos - so don't even bother with them.
Additional information is available both from Philips website and from Arcsoft's website.
-Tha Mp3 Doctor
Mar 25, 2009 | Philips SA3125\02 MP3 Player
MY GOGEAR NOT STARING
The solution to a Code 10 error is to disconnect the mp3 player from your computer, uninstall all of the Philips software that came with the device, restart your computer, reinstall the Philips software, and THEN and only then - connect your mp3 player to the computer.
-Tha Mp3 Doctor
Mar 06, 2009 | Philips GoGear SA3245/37 Digital Media...
Not Detecting Go Gear IN Xp
Connect your Go Gear to the computer
Open the Philips Device Manager - it came on the installation CD
Click on the Repair tab and follow the instructions
When in doubt, follow directions.
-Tha (Mean Grinch) Mp3 Doctor
Dec 21, 2008 | Philips GoGear SA178 MP3 Player
MP3 file error system
The Device Manager can be found on the installation CD, or by going to www.usasupport.philips.com
Aug 21, 2008 | Philips HDD1630 MP3 Player
VIDEO LAG!!
Download the latest version of Quicktime, and then reconvert the videos
May 25, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3245/37  Digital Media Player Logo
542 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
