Question about Dell Latitude D600 Notebook
Bluetooth light on, but laptop not been found
Hi, Please help I have a blue indicator light but cant find the laptop when searching with my phone. Suspect someone trird also to install an external bluetooth dongle but software did not install correctly. The built in bluetooth is not visible in device driver. Any suggestion greatly appreciated, thanks.
  • techbug May 11, 2010
    have you tried making the laptop "discoverable" in your btooth settings
  • Gopal Agarwal
    Gopal Agarwal May 11, 2010
    the laptop model details pls.
    Problem Solver:
  • 9 Answers
May be the hardware is switch off.contact your compputer manual on switching on the bluetooth dongle.
Posted on Mar 14, 2009
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
HI. I have a Motorola H670 Bluetooth. I've used it with two phones so far. Today I upgraded to Iphone 4. I can't get the BT to reset no matter what I do (following all instructions found). ...
Your phone will find your headset only if it is in pairing mode. This mode is denoted by its indicator light steadily lit in blue at the time you slide the call button towards the microphone (i.e. turn it on). If the light is not steadily lit then, you must ensure that all devices previously paired with your headset have their bluetooth radios turned off and try again. When the light is steady, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on the list of found devices. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is succesful, your headset should enter the stand-by mode. There might be an indication on the phone that a headset is connected too.
By the way, if your headset's user guide happens to be missing ,feel free to download it from this location.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 16, 2011 | Motorola Mobility H670 Headset
Hi. i want to check if my dell laptop inspiron
The WI-Fi LED is a sign that its Enabled or ON. The LED light on the side of the switch is called the Wi-Fi Catcher.The light operates as follows:
Flashing blue:
Searching for networks
Solid blue: Strong network found
Solid yellow: Weak network found
Off: No signal found
Please comment if the information has been helpful. Thank you and regards.
Jun 22, 2010 | Dell Inspiron 1525 Laptop
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
How can i pair the just wireless bluetooth headset with my phone
with the headset off, press & hold the power button for about 9 seconds until the indicator light alternately blinks red and blue. Set your phone to search for a new headset or bluetooth device. When it finds the headset, the passcode shoudl be 0000
Feb 27, 2009 | Just Wireless Bluetooth Headset Wireless...
Connect trueblue bluetooth headset to Samsung Eternity cell phone
hold your finger on the call button on your blutooth device for around 6-10 seconds, this should make a couple of lights flash, when it does this it is active and ready to pair uo, then search, it will ask you for a code, usually they are generic and are prob the following 1234-12345-1111-11111-0000-00000-5555-55555 eiter one of these should work
Dec 26, 2008 | Cell Phones
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Need a users guide (instructions)
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
Jun 12, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
Bluetooth device
Make sure your bluetooth is in Pairing mode first. You should hold down the on button for about 5 to 10 seconds and the indicator light should turn solid blue. Consult your user manual for more help
Jul 30, 2007 | Samsung SGH-d807 Cellular Phone
Dell Latitude D600 Notebook Logo
166 people viewed this question
Alun Cox
