Question about Philips GoGear SA3245/37 Digital Media Player
MY GOGEAR NOT STARING
I have a GoGear SA32xx 4Gb version. My problem is it is neither being detected in any Pc nor it is starting. When I ON it  the PHILIPS logo gets displayed and automatically it gets turned off . When I connect it to a computer and Check in devive manager I found this error  "This device cannot start. (Code 10)
Click Troubleshoot to start the troubleshooter for this device."
 so any one can give me advice how to resolve this problem
  • 8,596 Answers
The solution to a Code 10 error is to disconnect the mp3 player from your computer, uninstall all of the Philips software that came with the device, restart your computer, reinstall the Philips software, and THEN and only then - connect your mp3 player to the computer.
-Tha Mp3 Doctor
Posted on Mar 07, 2009
How can i get itunes to download on my phillips gogear 4gb?
Transfer music via Windows Media Player 10:
  1. Hook up your GoGear with the PC via the supplied USB cable.
  2. Make sure you connect your GoGear micro also to the main power supply.
  3. Launch the version of Windows Media Player 10.0 installed in your computer. Note: Once the device is connected to the computer, all playback or radio will stop.
  4. Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
    Click OK to close the windows.
  5. Click Sync.
  6. In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
  7. Click the check boxes next to any files you want to copy.
  8. In the Items on Device pane, in the drop-down list, click to select PhilipsGoGear to copy files to.
  9. Click the Start Sync 051028091952_1760.gif button.
  10. The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
  11. Repeat steps 2-5 for any other items that you want to copy to your portable device.
  12. Once the transfer is completed, close the Windows Media Player
  13. Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music via Windows Explorer:
Note! You cannot transfer pictures via Windows Explorer, for pictures use Windows Media Player.
  1. Connect your GoGear with the PC via the supplied USB cable. Make sure you connect your GoGear also to the main power supply.
  2. Launch Windows Explorer.
  3. Drag and drop your music files into the music folder of your GoGear.
  4. Once transfer is complete unplug the GoGear from the PC and enjoy the music on the go.
Jun 10, 2010 | Philips GoGear Flash MP3 Player
I have a GoGear SA32xx 4GB and I'm trying to drag songs and videos from iTunes to the media converter, but it won't let me because it says they are unprotected. All I want to do is get my songs from iTunes...
The "iTunes" files are indeed protected. You'll have to convert the music to another format first. You can burn them to CD and then rip them back to your PC or you can get conversion software, you could try here first:
http://undrm.info/remove-DRM-protection/
Jan 03, 2010 | Philips GoGear Flash MP3 Player
I have gogear sa32xx but it daes not connect with pc at oll and it con`t work olso
It needs to work through "MusicMatch". Your GoGear should have come with the CD to install the software. You must install the MusicMatch software. Once loaded, you may need to go to their website to see if you have the most current drivers and updates for things to work properly. Read all instructions about how this player works. It does not work in the same way that iPods do. You have to use the wheel differently.
Sep 25, 2009 | Philips GoGear SA3245/37 Digital Media...
NO HE PODIDO METER VIDEOS AMP4 GoGear SA32XX QUE NESECITO PARA METERLOS VIDEOS Y SE REPRODUSCAN
tienes que convertilos en swv formato y necsitas el convertidor que vino con el mp3 player es facil.
Jun 16, 2009 | Philips GoGear SA3245/37 Digital Media...
My GO Gear not starting
Did you try pressing the reset button on the bottom of the player next to the hold switch?
Mar 06, 2009 | Philips GoGear SA3245/37 Digital Media...
I transfered too much music, filled the memory, cannot delete
take a pin, hold down reset button, after about 30secs of holding it, try to power it on, if ur lucky nuthing is gone, if ur unlucky, it will be back to factory setting, with 0 downloaded files
Jan 03, 2009 | Philips GoGear SA3245/37 Digital Media...
Need download phillips gogear 4gb software
i need downnload phillips gogear 4gb software to add hardware
Dec 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Is it possible to download music to the Philips GOGEAR MP3 4gb player WITHOUT windows xp?
You would have to go on the site and download the software for Windows 2000 ( I saw they have a version for Philips Manager for other versions of Windows)
Jan 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA3245/37  Digital Media Player Logo
704 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
