Question about Minolta EP4000/5000 CS/PRO Copier
We want to remove m2 after service code - Minolta EP4000/5000 CS/PRO Copier
  • kabeercb Mar 29, 2009
    we want to remove m2 after service code" problem, and notify you when a new solution is offered.
    President:
  • Minolta Master
  • 990 Answers
Hello sir; After you set up all the PM cycle count you may press the "reset"key on the control panel.
Posted on Mar 22, 2009
How to remove error code M2
question too vague.
make? model?
example:
Re: Konika Minolta BizHub 163 - Error Code? M2
• To display the count of the supplies life counter.
When the counter reaches "0", life 1 will be detected and maintenance call M2 will appear.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
• To clear the count, use [CLEAR DATA] of the Service Mode.
Jun 06, 2015 | Office Equipment & Supplies
How to solve code m2 in minolta 211?
enter in the service mode by pressing utility - stop - 00 - stop - 01
go to clear and clear all the options showing.
Mar 12, 2015 | Konica Minolta Office Equipment & Supplies
What is solution for konicaminolta 164 maitanance call m2
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.
1-Press utility button on panel.
2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.
3-its the code to get into service mode.
4-After pressing above mentioned buttons you will enter into service mode.
5-Now select service choice option.select it by pressing OK button.
6-In service choice option you will see Maintenance count option.
7-Select it by pressing Yes or OK button.
8-There will be three options 0,1,2.
9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Jul 04, 2014 | Konica Minolta bizhub Office Equipment &...
Code m2
menu,quick setting,<<quick setting <> and go to service choise ,maintenanc 0 press sit down go to clear data and clear maintenanc and supplies
May 16, 2014 | Konica Minolta Office Equipment & Supplies
Can't copy giving Maintenance call (m2)
Sir/Mam, are sure of the model is C250 they do not give those codes.
Apr 14, 2014 | Konica Minolta bizhub C250 All-In-One...
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
Code m2 erreur minolta 5000
M2 mean s to remove the Waste Toner box in the back of the machine. Replace with a new one and reset the counter in service mode.
Nov 27, 2012 | Minolta EP4000/5000 CS/PRO Copier
Maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Dec 17, 2010 | Minolta bizhub 180 Black and White Copier
What the cause of minolta copier 2050,code m2
Drum and Developer have reached there life cycle. And need to be replaced. If your machine is till making clean copies then clear the Maint counter (2) in the service mode.
May 11, 2009 | Konica Minolta DiALTA CF910 Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
155 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
