Question about Nintendo DS Lite Console
I have a broken ds
My ds screen connector and the top screen hinge has broke i also think the speaker wire that is part of the connector is snapped is it easy to repair
Sorry. If thte screen conector is broken you must to change the screen
Posted on Mar 06, 2009
Brought a ds lite and new ds shell as the old one had broken hinge.Whilst re routing the black antenna cable broke (gold connection bit came off) i have ordered a new one from ebay.So as this is just for...
If you yourself have replace it, I think you damage the upper LCD ribbon connector. I have repaired a lot of DS, a broken hinge usually the cause of that problem( ribbon connector cut off ).
Check the upper LCD if that model have a seperate ribbon connector, luckily you could buy the ribbon only, if not, BAD LUCK, you have to buy a new upper LCD.
Hope that helps you out.
Thanks for asking FixYa!
Aug 08, 2011 | Nintendo DS Lite Console
My ds lite is broken from the hinges
You need a new case, fiddling with it whilst the hinges are broken can lead to broken top screen speakers/mic and wifi capability
Cases are on ebay and various other web sites for 10-20
Dec 08, 2009 | Nintendo DS Lite
The hindge is broken it leans the full way back and my touch
you broke the wiring that goes to the top screen through the hinge...
Jun 05, 2009 | Nintendo DS Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Thanks
Josh Boyer
ninja_freak318@hotmail.com
Jan 22, 2009 | Nintendo DS Lite Console
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
Jan 07, 2008 | Nintendo DS Lite Console
DS blinks and will not turn on
Hi
As complicated a console as the DS is, it is not surprising you have a problem after changing a case. Sometime the little snap on wires do not snap on right.  You need to go back in and  make sure the ribbons and snap on connectors are sucured. The ribbon and wire that runs from top half through the hinge needs to roll up one turn before in the transition from the top to bottom half.  You may have the ribbon upside down in the connector.
Oct 28, 2007 | Nintendo DS Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
70 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
