Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
I need replace the control board, but I can't find where purchase it.
    President:
  • 1,294 Answers
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
You can rate me........
Posted on Mar 06, 2009
My kenmore elite calypso will not do final spin.flashes LD. I replace the pump as was suggested,still did not fix froblem
Hello Alex;
My name is Peter. I am a retired field service appliance technician.
After review of your washer components, there is a strong possibility that you have a bad electronic control board. You have two control boards, one is for the motor and one for the other functions.
Washer electronic control board for Kenmore Elite Washer model #11021062001 Electronic control board 8571359 is the circuit board that manages the washer's functions, such as filling, washing, draining and spinning. It sends voltage to the drive motor and other electro-mechanical component.
Cost: $218.00
If you elect to replace the board make sure you ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock a board out.
All appliances with electric control boards should have a surge protector. You can purchase a wall socket surge protector for $20-25.00. It is a good investment considering how expensive control boards are.
Rule of thumb; "If the unit is either 7 years old or the cost of repair is 1/3 or more of the original price, purchase a new unit.
Consider it purchasing a new unit, stripping your existing unit for parts to sell on e-bay. You will make a little money and save others expensive parts cost.
Dec 03, 2014 | Kenmore Washing Machines
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
The TV turns on, but the picture and sound doesn't work. there is not static noise and the remote is unresponsive. i have tried hard resetting by unplugging it for several hours.
Unfortunately, you have a bad Timing Control Board (T-Con board) You will need to replace this or replace the TV at the store you purchased. This T-con board is not available at this time. Purchasing a replacement board is not a good thing to do. As this board will also have a defect. Find an authorized servicer of Haier to repair the actual board! This is good advice. Thanks for asking me. Sincerely, Matt of Martins TV.
Aug 01, 2013 | Haier Televison & Video
Pressure switch
contact the spares department of the manufacturer and make enquiries. My feeling is yes as most machines use a generic pressure switch.
Apr 28, 2013 | Fisher Paykel EcoSmart GWL15
WHY IS THE MACHINE SPINNING AND FILL WITH WATER AT THE SAME TIIME
This is a known control board issue with the Cabrio. If your unit still under warranty? If not, you will need to replace the control board. Be sure to purchase it new if you need to replace it so you can get a warranty on it. Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
No power to my microwave GE JVM1750DPBB
You're looking $130.49 for the board.
May 01, 2012 | GE Microwave Ovens
Radio volume control 2002 ford explorer is reversed
This is a common problem that occurs with Ford factory head units. Fortunately, it is repairable for about $30 if you don't mind investing an hour of your time. The display circuit board needs to be replaced. The board had your volume control integrated onto the board. You can purchase a replacement board at: www.oem-auto-accessory.com. Note, I have no affiliation with this company and I'm sure there are others that also sell te same part. This is where I purchased mine so I'm simply referencing at least one place you can source the part.
Jan 24, 2012 | 2002 Ford Explorer
I have GE Profile dishwasher Model PDW9880 series. It will not drain. We had a repair man come & he said it needed a new control board. Do you think this is true? If so, can I purchase one one my...
Of course you can purchase the part. Module runs around $100. Dishwasher control boards are usually easy to replace, but there's no way I can determine if you're capable of doing it.
Jul 14, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
I have a Kenmore Oasis HE top load washer; purchased it in 2006 and I had the foresight to purchase the master protection plan & extended warranty. I have had SEVERAL repair calls for a variety of...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Jun 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
83 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
