Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
I purchased my laptop on 5th Nov 2007, Model no. is HP dv 2601tx. It is getting hibernate in the middle of my work. please solve my problem. My email Id is arangi@in.com.
    President:
  • 1,223 Answers
See if it helps ur problem pls let me know if u need more help may be ur sleep time is set to 2 min or 5 minutes set it to 30 minutes and it will not bother upls dont forget to rate me FIXYA if i fixed ur problem
To change power management settings
  1. I purchased my laptop on 5th Nov 2007, Model no. - ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Power Options.
  2. On the Select a power plan page, click Change plan settings under the selected plan.
  3. On the Change settings for the plan page, next to Turn off the display and Put the computer to sleep, choose the display and sleep settings that you want to use when your computer is running on battery and when it's plugged in.
  4. Click Change advanced power settings.
  5. On the Advanced settings tab, expand the category that you want to customize, expand each setting that you want to change, and then choose the value that you want to use when your computer is running on battery and when it's plugged in.
    Suppose that you frequently use a mobile PC to give presentations, and you want the display to stay on during the presentations. Consequently, you also want the mobile PC to stay awake while you give your presentations.
    To keep the display on during presentations
    • Expand Display, expand Turn off display after, click On battery or Plugged in, and then click the arrow to change the setting to Never. You can also type the word Never in the box.
    To prevent the mobile PC from going to sleep during presentations
    • Expand Sleep, expand Sleep after, click On battery or Plugged in, and then click the arrow to change the setting to Never. You can also type the word Never in the box.
  6. Click OK, and then click Save changes.
Posted on Mar 06, 2009
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
HpPavilion DV 1000 stuck in hibernation mode
It will eventually come out of hibernation mode, when that happens go into power setting and select hibernation, next uncheck box on the left and click apply, this will disable this feature and should have no futher trouble.
May 29, 2012 | HP Computers & Internet
Can HP dv2715nr hibernate instead of putting it on sleep mode?
It sounds like the hibernate feature is missing from the power options list. Click on start button, select shut down, and then hold shif or ctrl and stand by should change to hibernate.
Let me know how you get on.
Regards.
Mar 11, 2010 | HP Pavilion dv2715nr Notebook
Motherboard Product no. needed
HP uses a proprietary motherboard. The only way you'll find the specifics is on your build sheet from HP or by contacting their tech/customer support department. Sorry I can't be of further help. Good luck.
May 04, 2009 | ECS PN2-SLI2+ (V1.0) Motherboard
Please help me track my MOTO RAZR2 V9
We have no way on FIXYA to track any phones .
Apr 14, 2017 | Cell Phones
Soniacanales
To get out hibernation GO TO >> Control Panel>>Display>>ScreenSaver>>Power>>Hibernate
UNCHECK the mark "enable hibernation"
Apr 06, 2008 | HP Pavilion dv1000 Notebook
HP PAVILLION dv 9000 laptop new bios instalation instructions
you need to go to HP web site , and down load the lates bios to update system
Mar 28, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
146 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
