Question about Motorola Mobility RAZR2 V8 Cellular Phone
My laptop doesnot recognize my cellphone
I want to connect my cellphone with laptop but there is error in connecting,laptop cannot recognize my cell phone.what is the problem plz tell me?
i have install the cd given i.e motorola phone tools installation cd.and i m connecting my cellphone by usb cable but it is not connecting.plz slove my problem fast it was working befor 6 month i was using it,but why it is not working now?
    President:
  • 1,738 Answers
Re-install the drivers.
Here is the link for the USB Drivers:
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=bda09ec8009a0210VgnVCM1000008806b00aRCRD
Here is the link for the Motorola Phone Tools Utility: (Vista 32 and 64 bit)
http://lfiles3.brothersoft.com/internet/mobile/Motorola_mobile_phone_tools4.5.1.zip
Please give me a big thumbs up when you rate my answer. Thanks!
Posted on Jan 27, 2010
Tip
How to Transfer Files from Cellphone to Laptop and Vice Versa
<span>There are three ways that you can use enable for you to transfer files from your cellphone to your laptop or vice versa.<br /><br /><span style="font-weight: bold;">1. </span> <span style="font-weight: bold;">By using a connectivity cable</span>. <br /><br />It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.<br /><br />A connectivity cable looks like this.<br /><br /><img src="carloadrian_2.jpg" /><br /><span style="font-weight: bold;">2. Bluetooth</span>. <br /><br />Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth. <br /><br /><a href="/../support/t8013435-connect_laptop">CLICK HERE</a><br /><br /><br /><span style="font-weight: bold;">3. Memory Card<br /><br /></span><img src="carloadrian_4.jpg" /><br /> <a><br /></a> <span style="font-style: italic;">SD cards are used in many cell phones</span>.<br /><br /> Many cell phones come with removable memory chips, which can be used to expand the available storage on the cell phone, or to transfer files (such as music and pictures) between the cell phone and other devices. Once you identify the kind of expandable memory in use on your phone, an adapter can usually allow you to connect it to a laptop as if it were a USB drive. <br /><br /><span style="text-decoration: underline;">INSTRUCTIONS</span><br /><br />1. Determine what kind of two-gigabyte memory chip your cell phone uses. You can do this by checking the specifications of your cell phone in the manual or on the manufacturer's website, or by removing the card and examining it. As of April 2010, the most common kind of memory card used in cell phones is the SD format, which comes in standard, mini, and micro sizes. Your phone may also use the Memory Stick Pro or Pro Mini format. The format type will be printed on the side of the card. <br /><br /> 2. Purchase a USB adapter for the card you are using, which is available from many different vendors. If your card is in a mini or micro format, make sure that the adapter comes with a sleeve for the card of your size; this allows you to insert a mini or micro card into the sleeve, and changes the card into a standard size for use with the adapter. <br /><br /> 3. Insert the card into the sleeve, if necessary, then into the adapter. Connect the adapter to a USB port on your laptop. The card will appear on your laptop as if it were a USB drive. When you are finished working with the card on your laptop, you can move it back to your cell phone.<br /><br /><br /> </span>
on Jan 28, 2011 | Cell Phones
My phone(nokia6500s)doesnot connect(through usb-CA101D) to PC SUITE
Ok sir try to connect your phone on the USB slot at the back of you desktop CPU or laptop. Power supply of USB at the back of your CPU is much sufficient to make your device work properly. Most of the times due to insufficient supply of power to the device makes the device to not work properly that's why it isn't recognized by the system..Hope it will help you
Jul 09, 2011 | Nokia 6500 Slide Cellular Phone
I am using samsung GT-S 5233a i got a pc studio disc with the phone. My laptop is windows 7 ultimate and i cant install pc studio to my laptop. because of that i cant connect to my phone with my laptop...
Perhapse this worked (without New pc studio, But install samsung Drivers from CD).
Solution: In your cellphone go to Settings---> Phone settings---> PC connections and select Media player option (or Ask on connection). Connect your cable (if you select Ask on connection option, you should response to your cellphone and select Media player option )and when the cellphone connected, open the My computer. Perhapse you can see your cellphone there.
Jul 05, 2011 | Samsung Star GT-S5233 Cell Phone
How to connect to laptop?
You can connect Nokia 2690 using bluetooth and using Nokia connectivity Cable CA-101 which will fit to the USB port of your laptop.
(NOKIA connectivity cable)
Procedure on how to connect:
1. Bluetooth (This will work with the laptop with bluetooth)
First, remember to turn on the Bluetooth feature and make it discoverable by other devices (My Phone's visibility -> Shown to all) on cell phone, so that it can be detected by laptop.
Then, click on the add devices in the control panel of your computer. Click start> control panel
2. Add Bluetooth Device Wizard window will appear, tick My devices is set up and ready to be found and click Next.
3. The wizard will then search the Bluetooth devices nearby, and will show the found devices. Here the wizard found my cell phone named David. Click the device you want to add, after that click Next.
4. Ok. Here the wizard will ask whether you need a passkey to add your device, so that the communication data between laptop and cell phone will be encrypted later, here I would recommend you to either select Choose a passkey for me or Let me choose my own key. In this example, I select choose a passkey for me.
The wizard will then show the passkey and you need to key in to your cell phone. After that, the laptop will try to install the Bluetooth device. If you have Bluetooth program for your cell phone, you can install it as Windows Vista might have problem to install the device . For my case, I install Nokia PC Suite on the laptop, so I can transfer wallpapers and videos later.
Note: Also your cell phone will get the prompt to accept connection from laptop, and you need to click yes.
5. At last, click Finish to complete the Add Bluetooth Device Wizard.
6. And now, you will see the new bluetooth device added which is your Nokia 2690 phone.
Here's another way on how to connect your cellphone to your laptop.
2. Hard Connection using Nokia connectivity Cable CA-101
carloadrian_7.jpgYou can get this from any nokia stores.
Procedure:
Just connect the other end of the wire to your cellphone and the other end to the usb port in your laptop. Follow the onscreen instructions in your cellphone.
Check your laptop if your cellphone has been detected, once it's connected you can then access your pictures or other files in your cellphone. You can even transfer files.
I hope this helps.
Please rate this solution. Don't forget to leave your comments/suggestions on how I can improve my service.
Thanks..
Jan 27, 2011 | Nokia 2690 Cell Phone
ERROR SHOWING ''CONNECTION FAILURE . CHECK INTERNET SETTINGS OR CONTACT. OPERATOR
sir please call to the related simcard customer care and say the cellphone model number.and the phonenumber then they will send the gprs settings to your cellphone save the settings and switch off your cellphone and again switch on.then connect the data cable from phone to the computer for connecting the internet...........
Jan 14, 2011 | Cell Phones
Why youtube doesn't work on my LG KP500 cellphone?
my phone model is LG KP500,but youtube is doesnot work my phone, please give good solution.
Jul 28, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
USB Device Not Recognized Error?
1.connect the USB cable to Mother Board Back side port, not for extension or frontside port.
2. Check Your USB Cable...make sure usb cables are correct
Jun 30, 2009 | Cell Phones
My cell phone sgh z500 cant be connected to pc through data cable. allthough the data cable is correct and sound. what is the reall solution?
I think the problem is that your computer doesn't recognizes your cellphone. You must have a pc suite of some sort ti interface the cellphone to the computer. Hope this solves the problem.
May 01, 2009 | Samsung SGH-Z500 Cellular Phone
Motorola Mobility RAZR2 V8 Cellular Phone Logo
113 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
