Question about Freezers
On my Servis M0330W 50/50 upright fridge/freezer, above the fridge door at the top front, there is 3 light panels, 1st left is a green to indicate power (I believe), middle is a red triangle (which is flashing), on left is a clear panel with a snow flake beside it, but no light visable, the unit is intermitantly running (although at this time I can't say if either unit is getting cold), any ideas as to the problem please
  • 2 more comments
  • pauld_humphr Mar 06, 2009
    Thanks for the info, system works like it says on the tin, good advice
  • pauld_humphr Mar 09, 2009
    I've bought and replaced the PCB board, no lights flashing now, freezer is now getting slowly cold, but fridge is not cooling at all, whats the way ahead, any help appreciated, thanks
  • 007nv May 07, 2009
    I have the same problem on my Servis m0330s. Surprisingly, freezer is ok but fridge is not cooling. I checked the motor out of the unit and it runs well on 240v but in-situ, it just about turns and is pulsating (speed varies). Checked voltage and that is also pulsating (going up/down, not constant 240v). Can't find a wiring diagram but suspect someting is dragging down the voltage? The lights in the front are also pulsating and sometimes, so does the relay and the inside light when the door is opened.
  • Anonymous May 08, 2009
    i was washing my fridge freezer then fridge light went out i closed the door for a while light came back on but then red light at top of door started flashing can anyone help thank you model servis m0330w
    New Friend:
I have defrosed my frezzer and turned it back on and the red light still flashing
Posted on Oct 13, 2016
  • 400 Answers
You need to replace this pc board, your unit seems to be short cycling because of a fault on the defrost side of the board.
Posted on Mar 06, 2009
  • Shane Seaman Mar 09, 2009
    1. Make sure that the fanmotor is working and you have good airflow through the cabinet, you will have to press the lever switch which is closed when the door closes or the fan will not come on.
    2. If the fanmotor is working fine, I would need to know if there is any cooling happening in either the freezer or the fridge side.
    3. Check that the compressor (black dome object at rear of unit) is actually running.
    4. If compressor is running, feel if the thin tube coming out of the comp is hot. Following it you will see it enter the cabinet and then return to a small cylindrical copper thing which is called a drier, the drier should be slightly warm. It then goes into a very thin capilliary tube. This should feel normal temp, no cold feeling.
    5. If your compressor is running and you are not getting cooling, there is very likely an intermittent blockage in the refrigeration system which can lead to compressor failure due to high head pressure. This would mean getting a repair guy to cut the tubes and test the compressor for pumping performance. The compressor is more than likely ok and he would need to flush the system with a solution to disolve the blockage. and then put it all together again. good luck and hope you come right
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
KFN 8862SD Fridge /Freezer The above unit is constantly building up ice on the fridge rear panel, despite having auto defrost! Help!!
1st stick a rag in the hole in the door (ice maker door) 99% of the time or o door gasket .... next ohm the auto frost coils to see if there in good working order, if they are it might be that you are low of freon. not a good sign
Jun 06, 2011 | Miele Freezers
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Servis fridge freezer
Hi ,
ngafm at your service,
If its cold and frozen it may be that the door switch that activates this light in the case that the door is ajar, is faulty.
Or it may be that the temperature is dropping to slowly for you to see it by eye!
The whole purpose of the, "door ajar" light is to protect you food from spoilage and to warn you before it gets to warm!
Door ajar or not!!!
My advice is to fix the problem now no matter if it is only the switch causing a false alarm.
Or the worst case scenario !
You need hands on service!
Bless You ,
ngafm,
please give me a good rating before you sign off.
Thank you.
Sep 07, 2008 | Freezers
Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 | Freezers
Servis fridge freezer mo330al lights
Hi there
  • Green = Ready (Power ON)
  • Amber = Super Speed Freeze
  • Red = Warning overheating or fault.
Hope this helps
Thanks J
Jan 04, 2008 | Freezers
It may be that the temperature of the unit is not yet up to temp.The flashing light will indicate this.Warning the user the unit is not ready,or up to safe temp.. Let the unit run to catch up,since you just started it.
Nov 30, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Freezers Logo
1,560 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
