When i'm turn on my pc this message would appear ''bios rom chesum error'' what should i'l do?
  • 271 Answers
ROM check sum errors happen after a failed attempt to update the BIOS or more frequently, when the system's RAM is bad. (The check summing happens when the main POST program is unpacked from ROM to RAM - so it fails when either is bad.)
So check your BIOS chip or RAM.
Thanks
Posted on Mar 06, 2009
  • 53 Answers
The ram has some error
better remove the rom blow air to it wipe it wit a clean soft  material
then replace the same
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
When I turn on the PC the following message appears and my system goes turn off... For Realtek RTL8101E/8102E PCI-E Ethernet Controller v2.13 PXE-E61: Media test failure, check cable PXE-M0F: Exiting...
This error occurs when the BIOS finds no hard disk drive to boot from, and tries and fails at booting thru the network jack (PXE Boot is a network boot used in large corporations, usually to image a system.)
Reseat the hard disk drive in the system, then reset the bios defaults and see if the system will boot normally. You can also try running diagnostics (Fn + Power on a Dell)
Most likely scenario is that the hard disk drive has failed and you will need to replace it.
Jul 15, 2011 | Computers & Internet
For Atheros PCIE Ethernet Controller... check cable connection PXE-E63:error while initializing the NIC PXE-MOF:exiting intel PXE ROM No bootable device-insert boot disk and press eny key happened after...
You didn't list your PC model or make, but it appears that you have enabled the network card to boot from it's rom chip. Turn that option off in your software or pcie Bios control.
Mar 15, 2010 | Computers & Internet
Got error message no bootable cd in atapi cd-rom
check your bios to make sure that it is set to boot from your HDD. If this setting is correct, perhaps your HDD is failed
Oct 03, 2009 | HP Computers & Internet
Bios rom checksum error
Hai, That message dosn't sound like an error. i suspect the ram is faulty/incompatible and the pc won't boot because of it.
Change back to the old ram and reset the bios (jumber on the motherboard)
Aug 07, 2009 | Computers & Internet
Won't run Windows. Message Appears:"NTLDR is missing. Press any key to restart. Press any key to restart
The most common problem for that error is that the drive isnt set to boot from cd so go into your bios and set to to boot from cd.
Jun 21, 2009 | Dell XPS M1530 Notebook
The following message appears as soon as I turn PC on; BIOS ROM CHECKSUM ERROR Detecting Floppy Drive A Media... Insert system disk and press enter My OS Microsoft Windows XP SP2 Bios : Award Bios...
There should be a jumper beside your bios batery there should be 3 pins move the jumper to the last 2 pins for 5 seconds and put it back that should do it
Mar 23, 2009 | Computers & Internet
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
