Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I HAVE 2GB PD COMPANY TRANSCEND IT IS DETECT BUT WHEN I DOUBLE CLICK OR RIGHT CLICK OPEN/EXPLORE FORMAT MESSAGE COMES IN PROPERTY USED/FREE BYTE 00
  • Anonymous Mar 15, 2009
    lease describe the specifics of your problem below. We'll add your post as a comment to patelhr82's "I HAVE 2GB PD COMPANY TRANSCEND IT IS DETECT BUT WHEN I DOUBLE C" problem,
  • 3 Answers
What operating system do you use ?
Have you try in any other computer ?
If using PC, try plug in direct to the USB port from the mainboard, do not use any USB HUB or extension.
Perhaps, it may be hardware defect.
You can try return to the store :)
Thank :)
Posted on Mar 13, 2009
Unable to format usb stick
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Aug 05, 2012 | Dane-Elec DaneElec 4GB USB Drive Copper...
My pendrive transcend jf v30/321 gb not store any data properly ,when i save any data to this pen drive but after few minutes above save data not working properly what shall i do
There are several possibilities:
1. Damage to the partition table. If there is damage to the partition table, use the JetFlash OnlineRecovery software. This software can be used to repair a flash drive and keep existing data. Repair flash drive RAW format, used space 0 bytes, free space 0 bytes, can't format, repair partition table, repair firmware, update firmware, and keep exiting data.
2. Flash drive bad sectors. To check for bad sectors, use the HD Tune software. The way: insert a flash drive, open the HD Tune software, select the drive, error scans, and Start. Picture.
If you find bad sectors in the flash drive, the solution: backup data, use software HDD Low Level Format Tools. Open HDD Low Level Format tools - select drive - continue - click SMART - Get SMART Attribuutes - click Low Level Format - Format This Device - Yes - wait until the end - OK. After the finish, remove the flash drive from the computer. Then enter again. Then format the flash drive and finish. Picture
Transcend
to repair bad sector, you can see in the video.
Sep 24, 2011 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Hello, I have a Sandisk Cruzer edge 4gb usb device Now it detected that used space 0 byte free space 0 byte please fixe my probleme. Imamul hazari from wb india imamul.hazari1976gmail.com
click start click on computer to open then you should see your usb drive right click select properties tools check now tick in both boxes start to check for and attempt recovery of any bad files and bad secors on your usb drive you should not have any input while the chkdsk utility is attempting a repair any input might damage this drive
hope this helps
Jul 26, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk
4 GB pen drive show property as 0 byte used and 0 byte free..when subjected to open show insert disk please help!
Aug 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HI, TRANSCEND EXTERNAL HARD DISK FOLDERS NOT OPENING
try to format the HD using disk management. right click computer select manage then disk manager. look for your external HD and click format.
Mar 26, 2010 | Computers & Internet
I can not format my usb and the total capasity
Format the Data Traveler:
Warning! All data will be lost.
1. Insert the DataTraveler into a USB port.
2. Right click the Start button via the Windows Start menu and slect Explore.
3. Locate and right click the Kingston removable drive.
4. Select Format from the pop-up menu.
Note: Always use standard FAT for drives 2GB and smaller. Always use FAT32 for drives 4GB and larger.
5. Click the Start button. A format Removable Disk Warning will come up. Choose OK if you want to format your drive. After the drive has been formated you will receive a Format Complete box. Click the OK button.
Hope that helps.
Jan 12, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I HAVE TRANSCEND 2GB PEN DRIVE WHEN I DOUBLE CLICK OR RIGHT CLICK OPEN/EXPLORE FORMATE MESSAGE COMES IN PROPERTIES FREE AND USED BITE 00
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2.b) Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Mar 06, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Hard disk problem
First u should format disk from disk management mmc snap or from command prompt.without formatting a disk's properties says 0 bytes used and 0 bytes free space.
Sep 03, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
61 people viewed this question
Top Kingston Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
Florin
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
