Question about Car Audio & Video
Installing RCA outputs on an EQ.
On my 9band graphic equalizer booster there are RCA input leads.but only speaker wire outputs.The circuit board has marked locations for RCA outs.Can i install my own?or is there a reason their not there?
  • 111 Answers
You can, but first touch the 2 speaker wires to the RCA connections on the circuit board and see if sound comes out. IF so, then solder in 2 RCA jacks
Posted on Mar 07, 2009
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
I need a wiring diagram to get the color codes for a realistic 40 watt equalizer booster model 12-1954
All the wires on my 40watt realistic eq are all the same thickness and I have three red wires can someone tell me what side the power wire should be on and which color wires would go for speakers and which color go for the amplifier
May 09, 2012 | Car Audio & Video
Dose the pyramid 801 EQ have wire outputs or RCA outputs
This unit actually has high-power, speaker-level outputs, since it is an amplifier and EQ together.
Feb 03, 2011 | Pyramid 801 10-Band Car Equalizer
How do I hook up the two stereo output RCA wires ( 1 L & 1R ) to the EQ input wires that are green/green&white & grey/grey&white?
you will only be able to control 1 pair of speakers, you can try an inline converter. always buy a stereo with 3 preouts especially if you plan on using equalizers/amps ect
Sep 12, 2010 | Pyramid 801 10-Band Car Equalizer
How to hook up a equalizer
i believe you need to be running an aftermarket amplifier to use this E.Q. does it only have RCA inputs and outputs on the back of it? if it does, you'll need to run the rca's out of the radio into the E.Q. then run the rca out's from the E.Q. to the inputs of your amplifier. and of course there's probably a constant 12v, a switched 12v, and a ground you'll have to wire up.
Feb 17, 2010 | Kenwood KGC-4042A 5-Band Car Equalizer
I would like to hook-up amp to graphic equalizer i would like picture if possible.
An EQ (equalizer) is generally connected between the low level output of a device (phono, CD, DVD, etc.,) and the amplifier's input. If you choose to place the EQ at this point, only the device connected will be equalized. All the other sources will be unaltered.
A more complete way is as follows:
Some amplifiers have a jacks labeled Left & Right "PRE OUT" and Left & Right "AMP IN" with a heavy gauge wire or strap that connects the left AMP IN & left PRE OUT together; and the right AMP IN and right PRE OUT together. Removal of the wire or strap will cause the amp to fall silent, as the low level signal no longer has a path from the PRE OUT to the AMP IN jacks. If you were to insert the EQ here, the path would be restored - but allowing you to boost or cut the level of certain frequencies BEFORE they are amplified. This is accomplished by connecting PRE OUT to EQ IN and EQ OUT to AMP IN for both the left and right channels.
As I mentioned, only some amps have these PRE OUT and AMP IN jacks - many however do not. In this case, you may be able to use the TAPE MON jacks. The TAPE MON is the Tape Monitor and appears on most "half-way decent" receivers. These jacks were provided to enable listening to a tape in nearly "real time" as it was being recorded on higher end "3 head" tape recorders. If you don't have a "3 head" tape deck (most do not), you can use these jacks the same as the PRE OUT and AMP IN jacks above. This is accomplished by connecting the TAPE OUT to EQ IN and the EQ OUT to the TAPE IN for both the left and right jacks. You would then select the source of the music - be it CD, Phono, etc. and with the EQ powered, pressing the TAPE MON button on the receiver, you could hear the difference between the EQ in the circuit and the EQ out of the circuit.
The key in the examples above is that there is always an input connected to an output. Don't connect inputs to inputs and outputs to outputs. Take your time and work one cable at a time - one end to an input and the other to the corresponding output.
Some situations may arise if using Dolby Digital, THX, etc. type input signals. Sometimes it is not possible to equalize them. If you have sources (DVD, Satellite Receivers, etc.) that have an optical or coaxial connection, those will be the ones that may have undesired affects. The familiar RCA type jacks for left and right signals should work perfectly.
I'll see if I can find a link with a picture...
Sep 29, 2009 | Audio Players & Recorders
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
Hi I would like to know how to wire up a kam keq 15 dual band graphic equalizer to my home hifi thanks
Either run the main ouptut for your amp to the input of the eq and output of the eq to the main input of your amp OR use one of your tape monitors on your amp. Record on your amp goes to eq input and play on your amp goes to eq output. Hope this helps you.
Jul 29, 2009 | Audio Players & Recorders
Installation
take two out puts from your cd player and run them in the inputs of the equalizer and believe me they are going to work.Remember if the outputs from your CD player are of high note (out put)the volume should be kept at minimal to avoid the rumble.
Aug 18, 2008 | Pyramid 10 BAND EQ 300 W WITH LIGHTS Car...
Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Jul 07, 2008 | Car Audio & Video
Car Audio & Video Logo
381 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
