Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
1Sony LCD TV KDLS40A12U won't switch on - green & yellow blinks
1 After swiching TV off at wall, it will not now power up. Instead of going on to standby (with red light on) it seems to rapidly switch itself on and off with the green (power) and yellow (timer) lights flashing on & off.
  • Anonymous Mar 08, 2009
    my sony kdl-s40a12u won't switch on the green and yellow lights just keep flashing
  • 4,234 Answers
Check the owner's manual for this code. Under the troubleshooting section, the flash code usually means that the lamp is bad or there is a temperature or fan problem. I don't have the manual for your specific model with me at the moment. If you have had this unit for a while, I would first suspect the lamp as being defective. I'll look up your specific model later today when I get back to the shop.
Dan
Posted on Mar 06, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
I hav an LC AQUOS TV Model Number LC-C3234U..The power button keeps going off and blinking green..tried holding power button down but it comes on yellow and then goes to sleep blinking green again..wh
These blinks are fault indications. Count the number of blinks occurs at one time switch on, and check this link for details. The link contains the blinking codes to many brand TVs.
Jan 29, 2013 | Sharp Aquos LC-C3234U 32 in. LCD TV
Green power light want stop blinking
Problem is with one of the circut boards in the tv, It will have to be replaced.
Oct 21, 2012 | Sanyo DP19647 19 in. LCD TV
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
Green power light blinks for 1 minute then the lamp light blinks
When Lamp of the TV has been blown out, the LAMP light blinks in red.
When there is an internal malfunction in the TV, the Power led blinks and there will not be any picture on the screen.
Since, both are happening with your TV, it seems that there is an internal malfunction. Hence, your TV requires service.
You may try the following troubleshooting steps before getting the TV serviced.
Disconnect the Power cord from the Wall outlet and connect it to a different working wall outlet.
Disconnect surge protectors if you are using.
Then try resetting the TV to the Factory default settings to check whether the issue is resolved.
Jul 14, 2010 | Sony KDF-E42A10 42 in. LCD Television
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
My Magnavox 52" LCD tv blinks red and will not come on (by the remote or the power button on the tv). I have to disconnect the tv from the wall plug for few seconds. It will come on green and work...
Ur power supply board have problems,just not dead yet.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 23, 2010 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Vizio 32 does not turn on
The tv not not power 0n dead set,1 ic blown out stby sw,how I can fix the board.Thank you.
Jun 21, 2008 | Vizio L32 32 in. LCD HDTV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
257 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
