Question about Sony RDR-HX725 DVD Recorder/HDD Recorder
DVD Lens problem
My DVD drive is not even reading the discs. Need to replace it. Can we replace with any other DVD units or only Sony DVD should be replaced with
    Problem Solver:
  • 15 Answers
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Posted on Mar 10, 2009
Wont read any disc
The problem is quite common.
When your console does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the PS start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the PS, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
before doing tis, contact Sony to check if the unit can be replaced or repaired by Sony, you find the number on the Console documentation.
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Disc cannot be read
When your console does not read any disk, that is usually because of a problem with theoptical laser lens that is dirty, faulty or opaque, and will startoperating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, butthe TOC (table of content track at start of CD/DVD will not be read,therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD.After more prolonged usage , often the PS start losing the rest offunctions, and ends up not reading anything atall.
If instead there is no noise, and disk does not spin at all , thenthere is a faulty motor, or the motor micro-switch is bad. Thissituation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that doesnot work you will need to disassemble the PS, and clean lensdirectly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
before attempting repair , contact Sony to check if the unit can be replaced orrepaired by Sony, you find the number on the Console documentation.
See also the movie below :
Sep 04, 2009 | Sony PlayStation 2 (PS2) Console
Sony vaio VGN-CR320E dvd drive issue
i'm sure some problems with your dvd lens, first clean your lens with dvd lens cleaner and play after finish tracking.
May 06, 2009 | Sony VGN-CR320E/P Notebook
Place DVD in any slot and it says "reading disc" then "no disc"
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
May 04, 2009 | JVC THC5 Home Theater System with 5-Disc...
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Will not read DVD discs.
It looks like you have a lens problem, DVD and CD use a different error correction and different track format.
A dirty lens can read CD but not DVD.
Tru first using a lens cleaner like this ones:
If it does not work you can try cleaning the lens directly with cotton and isopropyl alcohol, you will need to undo the screws at the button and to take apart the cover. Unplug power when doinfg this.
If it still does not work, since you aready reinstalled the firmware, the lens may be faulty.
You can order the lens pickup from factory and replace it.
Sep 02, 2008 | LG Computers & Internet
Bad disc
Try cleaning the lens yourself. Before taking drastic measures as replacing stuff, try cleaning the lens on the DVD/CD Drive. You will need to open the unit and also open the DVD/CD case. Make sure you do this while the unit is unplugged from a power source. Locate the lens that reads a dvd/cd. Now get a cotton swab and moisten it with isopropyl alcohol (rubbing alcohol) and gently rub the lens clean...use the other dry end of the cotton swab to rub it as well. Try not to use too much alcohol on the swab and not too much force when rubbing. Let it dry for a minute or 2 and screw the unit back into 1 piece. Moisture, cigarette smoke, insence smoke, and dust can cause a barrier between the DVD/CD and the reading lens and by doing this you will either fix the unit or know that it is a problem that will need replacing. Good luck!e lens yourself manually
Jun 23, 2008 | Cyberhome CH-DVD 300 DVD Player
Cd not reading
problem no disc when this is a disc in the player
Jul 08, 2007 | TruTech TT1620 DVD Recorder
DMR E55 won't read RAM Discs
while you was replacing the voltage regulator you damage part of the microchip computer replace it.there after your worries will be over
Mar 26, 2007 | Panasonic DMR-E55 DVD Recorder
DVD Drive Replacement VX-500
Some of the dvd players you can replace the deck with a dvd drive.If it has the power and normal computer dvd rom plug you can replace it and it should work.It is easy to do.just plug the old unit out and the new one in.
Mar 28, 2007 | Sony RDR-VX500 DVD Recorder/VCR
Sony RDR-HX725 DVD Recorder/HDD Recorder Logo
188 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
